Help with re-build.. Please read!!!
Old Nov 27, 2007 | 11:44 PM
  #26
ek_b16's Avatar
Default Re: (blinx9900)
It wont pass the cruse idle.. Says it has to much hc or something like that.. Its got a obd0 b16 swap and has a race cat.. I've only passed emisson once with it but that was a few years back.. NOw the car has a battery issue.. I've gone threw 2 new batteries now.. The car starts up fine then once the battery runs out the car dies and I gotta recharge.. its not the alternator..
Old Nov 28, 2007 | 12:10 AM
  #27
blinx9900's Avatar
Default Re: (ek_b16)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek_b16 &raquo;</TD></TR><TR><TD CLASS="quote">It wont pass the cruse idle.. Says it has to much hc or something like that.. Its got a obd0 b16 swap and has a race cat.. I've only passed emisson once with it but that was a few years back.. NOw the car has a battery issue.. I've gone threw 2 new batteries now.. The car starts up fine then once the battery runs out the car dies and I gotta recharge.. its not the alternator.. </TD></TR></TABLE>
hc=hydro carbons and race cats usually only pass the first year there in use if that, my friend works at a smog station i know this isent the topic of the thread but i'll ask him his opinion on why its not passing, im betting its the car, we'll see
Old Nov 28, 2007 | 12:51 AM
  #28
SoTexDC2's Avatar
Default Re: Help with re-build.. Please read!!! (HiProfile)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HiProfile &raquo;</TD></TR><TR><TD CLASS="quote">I just hope you didn't pull the cams out yet because of some other little noise </TD></TR></TABLE>
Not sure if you were trying to say something else, but he pulled the cylinder head already, and that's impossible without removing the camshafts first.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JaredKaragen &raquo;</TD></TR><TR><TD CLASS="quote">valve guide seals completely.</TD></TR></TABLE>
Valve guides do not "seal".
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blinx9900 &raquo;</TD></TR><TR><TD CLASS="quote">true but usually the valve guide seals go</TD></TR></TABLE>
The valve seat ensures proper seal to the combustion chamber, not the guides or stem seals. Engines with bad valve stem seals or worn valve guides won't necessarily result in low compression readings, unless the seat surface is out of tolerance.
Valve Guides are the internal sleeve which guides the valves angle and motion, located under the Valve Stem Seal.
Valve Stem Seals keep oil from protruding down the valve stem, through the guide, and making its way into the combustion chamber when the valve is open.
Old Nov 28, 2007 | 01:00 AM
  #29
blinx9900's Avatar
Default Re: Help with re-build.. Please read!!! (SoTexDC2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SoTexDC2 &raquo;</TD></TR><TR><TD CLASS="quote">
im aware of that, i was just saying in my experience its more often the seal then the seating of the valve...
Old Nov 28, 2007 | 01:18 AM
  #30
SoTexDC2's Avatar
Default Re: Help with re-build.. Please read!!! (blinx9900)
That was directed to everybody using the term "Valve guide seal" in this thread, and not you in particular.
Old Nov 28, 2007 | 09:18 AM
  #31
blinx9900's Avatar
That was directed to everybody using the term "Valve guide seal" in this thread, and not you in particular.</TD></TR></TABLE>
ya know i always thought the name didnt fit, now i know but why does everyone and there mom call it that? even the machine shop calls it that
Old Nov 28, 2007 | 11:56 AM
  #32
SoTexDC2's Avatar
ya know i always thought the name didnt fit, now i know but why does everyone and there mom call it that? even the machine shop calls it that </TD></TR></TABLE>
I am only familiar with honda's so I have no idea. Maybe other manufactures have a valve guide and stem seal that is all one piece, although I don't understand how that would work.
Ask your machine shop next time you talk to them?
Edit: After thinking about it for a bit, its possible that because it keeps oil above the valve guide, they call it the valve guide seal. The terms I use come from the helms though.
Modified by SoTexDC2 at 3:14 PM 11/28/2007
Christopherian1982
Jun 14, 2008 10:57 PM
DC5Kid817
10
May 4, 2007 01:31 PM
NAEK
Aug 22, 2005 12:24 AM
H.A.R.T B18C1EG6
Oct 4, 2004 10:18 AM
Ryan C
Jul 7, 2003 08:19 PM
