Help Please having problems
Old Apr 30, 2008 | 11:33 AM
OHmotorsports's Avatar
Default Help Please having problems
Hi I have a turbo setup and where the intercooler piping and the turbo meet the silicone coupling keeps falling off under boost.I need a solution to this,to where it wont blow off.Im running about 18psi and it wont stay on.Is this supposed to be welded on?Is there some sort of glue or epoxy?Any help please!
Old Apr 30, 2008 | 11:39 AM
chimmike's Avatar
Default Re: Help Please having problems (OHmotorsports)
t bolt clamps being used?
If you're not using t-bolt clamps, start.
If you are, it's not being secured properly, somehow.
Old Apr 30, 2008 | 12:14 PM
totsie7944's Avatar
Use t-bolt clamps....if that stll doesn't work you need to get someone to weld a beed around the opening so that the clamp has something to bite onto...
Old Apr 30, 2008 | 12:32 PM
Default Re: Help Please having problems (totsie7944)
I got some screw on clamps that came with it.They wont hold at all.Should I use hairspray?
Old Apr 30, 2008 | 02:37 PM
GT35R_EF's Avatar
Make mine whatever you want
NO, not hairspray, just T-bolt clamps, not the typical philips/flat head wimpy little clamps. The ones you have are probably not T-bolt. Just search T-bolt clamps anywhere, here or google or whatever and you will find it. Or pick them up at a local performance shop.
Old Apr 30, 2008 | 05:33 PM
totsie7944's Avatar
The screw on clamps will probably strip the head of the screw before you will get them tight enough not to come off under boost... you need at minimum T-bolt clamps...www.full-race.com sells them, among many other places.
Old May 1, 2008 | 05:42 AM
thanks guys
Old May 1, 2008 | 07:12 AM
Full-race.com does not carry 3in t bolt clamps.Would lowes carry something like that?
Old May 1, 2008 | 07:23 AM
Running925's Avatar
where in ohio are you at. Summit Racing and Jegs are both located here. Try them!
Old May 1, 2008 | 07:47 AM
Schister66's Avatar
Man U FTW
I've always cleaned my IC piping and used hairspray in conjunction with my 2.75" T-bolt clamps. It's a tad overkill, but i dont want them falling off.
If T-bolts dont work for you, you can have the ends bead rolled. If you're truly a baller, get yourself a set of Wiggins clamps
Skeero
Welding / Fabrication
12
Dec 28, 2011 09:20 PM
Skeero
Dec 27, 2011 08:30 AM
b16bri
Mar 3, 2011 09:11 AM
reed857
25
Jun 20, 2006 11:22 AM
