Help with piston and rods
Old Aug 7, 2006 | 12:17 AM
solspeed's Avatar
Default Help with piston and rods
Do you have to do any work to the block<U></U> when installing aftermarket piston and rods from high compression to lower aftermarket piston ( Je piston). thanks
Old Aug 7, 2006 | 01:36 AM
Speed Infliction's Avatar
Default Re: Help with piston and rods (solspeed)
if your block is in perfect shape (probably not) all you have to do is hone it...but usually you will need to bore it .020 over. that will get rid of all the scratches and make the cylinder walls perfectly round again as the may tend to get an oval shape to them.
Old Aug 7, 2006 | 05:16 AM
F20Cteg's Avatar
Default Re: Help with piston and rods (Speed Infliction)
If you can still see the original hone marks and the walls look good with no scratches or anything, then you're fine.
Old Aug 7, 2006 | 07:13 AM
RyanEJ8's Avatar
Default Re: Help with piston and rods (F20Cteg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by F20Cteg &raquo;</TD></TR><TR><TD CLASS="quote">If you can still see the original hone marks and the walls look good with no scratches or anything, then you're fine.</TD></TR></TABLE>
Not really. Probably going to need a bore to get piston-cylinder wall clearances in spec with the aftermarket pistons specifications.
Old Aug 7, 2006 | 01:41 PM
Default Re: Help with piston and rods (RyanEJ8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RyanEJ8 &raquo;</TD></TR><TR><TD CLASS="quote">
Not really. Probably going to need a bore to get piston-cylinder wall clearances in spec with the aftermarket pistons specifications.</TD></TR></TABLE>
true. also it is rare that your block will be perfect after driving on it for many miles and years. unless you never did either one of those.
Old Aug 7, 2006 | 05:30 PM
86si's Avatar
do it right. bore it .020 over and hone it.
Built4Battle
Feb 24, 2011 03:04 PM
philliedawg
Mar 1, 2008 02:30 PM
CivicVX94
Feb 6, 2006 11:35 PM
ptsaurus
Mar 20, 2004 05:33 PM
ntegls
Feb 22, 2004 06:11 PM
