help oil in down pipe
Old Mar 19, 2004 | 07:49 PM
DXK Eg's Avatar
Default help oil in down pipe
ok, i'm running a Garrett t3/t04e on a b16a2 and i'm smoking. But thats all and then theres oil in the down pipe no much just a few drop here and there. I was told thet garrett turbo don'y like alot of oil and was told to buy a oil restrictor, but i don't know where to buy one at? Checkers,Auto zone??? And one more thing any one running dsm injectors on a obd2 civic? i don't know were to get the yellow/black wire from the ecu? can i just use one from the post injector connection.
Old Mar 19, 2004 | 09:34 PM
beepy's Avatar
Default Re: help oil in down pipe (dynasty-x-motorsport)
You're right, Garrett's don't like too much oil. Unfortunately too much oil doesn't cause a leak, it usually blows out the seal.
You can make a restrictor yourself. One of the fittings in the feed line is bound to be either brass or aluminum. Take it out, braze the hole closed, then drill a smaller hole.
96ekb20
Aug 13, 2016 08:44 AM
boostedteg4dr
Oct 17, 2007 06:26 PM
MantisX
Sep 14, 2007 06:36 AM
djnikko
Aug 12, 2003 06:28 AM
boostin b16
Mar 15, 2003 05:44 PM
