help o2 question
Old Sep 10, 2002 | 04:05 PM
turbod16y8's Avatar
Default help o2 question
hey sup guys yes i did a search. My car boggs alot would a o2 sensor cause this?
Old Sep 10, 2002 | 07:25 PM
turbod16y8's Avatar
Default Re: help o2 question (turbod16y8)
ttt
Old Sep 10, 2002 | 07:34 PM
niedejb's Avatar
I would point to over/under fueling and spark plug gap before I looked at O2 sensors.
Your CEL will tell you if the O2 sensor is bad.
You ever been to a dyno?
Old Sep 10, 2002 | 07:50 PM
turbod16y8's Avatar
Default Re: help o2 question (niedejb)
my ngk 2 step colder plugs are gapped at .030 and im running a 255 walbro intank and a B&M fpr and 12.1 FMU. plugs are very black which means im running really rich. could this be the problem?
Old Sep 10, 2002 | 07:55 PM
niedejb's Avatar
Yep. I was running so rich when I dynoed that their wideband couldnt pick it up.
It was falling on its face under boost.
Old Sep 10, 2002 | 08:49 PM
CzanSOHC's Avatar
dyno tune it it..and lean that out.
Old Sep 10, 2002 | 09:38 PM
ion_four's Avatar
Default Re: help o2 question (CzanSOHC)
Bogging would not be caused by a faulty o2 sensor, because your engine is relying on the MAP sensor at high-throttle. it only uses the o2 for idle and cruising (and people use it for a bit of tuning). you are probably running too rich. the sparkplug gap would probably cause your power to fall off up top, not bog down low, I believe.
Old Sep 11, 2002 | 11:47 AM
turbod16y8's Avatar
Default Re: help o2 question (ion_four)
thanks for the ehlp i fix my problem. got a b&m and turned down the fuel and now everythigns working great thanks guys
livedew12
Jan 10, 2012 08:58 PM
ATS*Mark
Apr 7, 2004 07:06 AM
turbo Si
Mar 10, 2003 02:56 PM
