Help needed on deciding on an optimal wastegate size.
Old May 13, 2010 | 06:50 PM
Slow_boost's Avatar
Default Help needed on deciding on an optimal wastegate size.
My setup consists of a built z6. Will be using a ramhorn manifold and a turbonetics .57 trim with a stage 5 comp wheel. Im only look for around 300hp. I need to know if a Tial 40mm wastegate will be too big? Too small?
Thanks in advance. I need some answers so I can pull the trigger on a deal.
Old May 13, 2010 | 08:07 PM
drift2004's Avatar
Default Re: Help needed on deciding on an optimal wastegate size.
Bigger than nneeded. U should use a 38mm
sykotik sol
Aug 18, 2008 02:38 PM
ildknyli
Sep 12, 2004 01:10 PM
APEXI Si
Aug 31, 2002 07:42 PM
