Help - need help on wiring apexi turbo timer!
Got a free tubo timer from my friend, but he doesn't have the instruction manual anymore, so i don't know what the wires are.
This is not the small slim turbo timer which apexi now sells, it's a small lil box one. The serial # for it is AT2 9711-0390. If anyone has this, could you please tell me what the red, green, black, white and blue wires represent. thanx |
Re: Help - need help on wiring apexi turbo timer! (98teg)
ttt
red is constant 12v,green is primary ignition,blue is second ignition or accesory,black is ground,white is o2 signal and gray is parking break
Re: Help - need help on wiring apexi turbo timer! (turbotypeR)
thanks for the info, this is greatly appreciated. However, I only have one problem. I'm not sure if one of the wires is white or gray. Does the turbo timer require a connection to the parking brake and the 02.
thanx |
parking break is req. connection I thought.
a/f just wont have a reading but the timer should work. |
Re: Help - need help on wiring apexi turbo timer! (twkdCD595)
you do not need to hook up o2 or parking break
thanks for the info guys. I guess i try to see if it hooks up to the parking brake then. It looks like a really simple timer that wouldn't require a o2 connection. It' just looks like all it does it count down
