Help! Looking for belts for JRSC
Old Dec 17, 2010 | 09:53 PM
shahriar35's Avatar
Default Help! Looking for belts for JRSC
Is there an alternative to purchasing belts for a JRSC?
I purchased a JRSC for B16a1 (Civic Si), but I am mounting it on my B18c5 (ITR), I need the following? But can I purchase them from somewhere else for less, if so part numbers please.
051-110 $15.00
Belt - 4PK800, Crank to Alternator
051-263 $15.00
Belt - 4PK620, Alternator to Supercharger
Thanks
Old Dec 18, 2010 | 01:14 AM
Gold DA9's Avatar
Default Re: Help! Looking for belts for JRSC
take the belts part numbers to advance, autozone, or napa and see if the can cross referense them. The 4PK800 and 4PK620....
Old Dec 18, 2010 | 05:32 AM
silv00teg's Avatar
if you go to napa the part numbers are 4pk800= 25-040315 and the 4pk620= 25-040245. i work for napa and i am currently at work reading this thread. hopes this help you
Old Dec 18, 2010 | 07:46 AM
bgdriver's Avatar
autozone would be 800k4 and 620k4 respectfullly. it's an 80.0 in belt with 4 ribs and a 62.0 in belt with 4 ribs.
Old Dec 18, 2010 | 10:49 AM
Jaker's Avatar
And if they don't have the belt in 4 rib, buy a 6 rib or an 8 rib (or even a 10) and cut it down. It's super easy, and if you get an 8 rib, you can make 2 - 4 rib belts out of it.
Old Dec 18, 2010 | 01:50 PM
shahriar35's Avatar
Thanks all!
Old Dec 18, 2010 | 05:01 PM
shahriar35's Avatar
So autozone couldn't help me. Those part numbers given for autozone didn't work. They also couldn't cross reference using jrsc numbers.... What size are the two belts?
Old Dec 18, 2010 | 11:42 PM
silv00teg's Avatar
4pk800 :# Serpentine Belt Ribs : 4
Belt Angle : 40 Deg
Outside Circumference (in) : 32.216"
Outside Circumference (mm) : 818 mm
Section : K
Top Width (in) : .56"
Top Width (mm) : 14 mm
4pk620: # Serpentine Belt Ribs : 4
Belt Angle : 40 Deg
Outside Circumference (in) : 25.215"
Outside Circumference (mm) : 640 mm
Section : K
nholmes
May 15, 2006 10:58 PM
JDMBOLONI
Nov 13, 2004 10:41 AM
jbs
Mar 10, 2004 10:25 AM
