help: look at this manifold!
Old Aug 14, 2002 | 05:49 PM
uNF$@#!'s Avatar
Default help: look at this manifold!
this is the part of the manifold that connects directly with the block.
should i be concerned about the "dents" in the opening? they are slightly raised, so it may be a problem with seepage...
any opinions? could use some advice.
sand it down and ready to go? any advice?
[Modified by Soup ****, 9:53 PM 8/14/2002]
Old Aug 14, 2002 | 05:56 PM
Giuseppe's Avatar
Default Re: help: look at this manifold! (Soup ****)
that pic isnt that great, but it should sit flush, to allow no exhaust leakage.
if its a custom piece youve made, i wouldnt worry too much about perfect
circumference welds..but if youve bought that thing,
just sand down the openings as round as possible..
and manifolds get bolted to heads, not blocks,
Old Aug 14, 2002 | 05:58 PM
uNF$@#!'s Avatar
Default Re: help: look at this manifold! (Giuseppe)
thanks!
oh, and if there are little bits and shavings inside the manifold...whats the best way to get it out? cloth? ... i guess i'll try compressed air.
Old Aug 14, 2002 | 06:07 PM
Giuseppe's Avatar
thanks!
brake cleaner ( in a can)
or rinse it with gasoline
Old Aug 14, 2002 | 07:16 PM
Full-Race Geoff's Avatar
that looks fine, no need to worry at all. The weld looks like it controue the runner and i really doubt it will leak. rough picture but a little touch (not much!!!) with a die grinder wouldnt hurt, but i assure you it would only be for peace of mind. It would really make no measureable performance difference whatsoever.
Old Aug 14, 2002 | 07:17 PM
if its stainless steel just use a hose, the coolant is water soluble and the chips will just let go.
Old Aug 14, 2002 | 09:35 PM
HybridKOOP's Avatar
Default Re: help: look at this manifold! (FFgeoff)
Sell me your rear emblem and I'll tell you ;-)
Old Aug 15, 2002 | 05:37 AM
bhaz413's Avatar
clog the hole with a rag before you grind
Old Aug 15, 2002 | 07:03 AM
X2BOARD's Avatar
Looks like a pic from the Apollo moon landing...
{Best Homer Voice} NASA....
Old Aug 15, 2002 | 09:47 AM
DLB1994's Avatar
Default Re: help: look at this manifold! (X2BOARD)
haha
turbodailydan
Welding / Fabrication
56
Dec 4, 2009 06:43 PM
portenio78
Mar 5, 2008 09:32 AM
.john.
13
Feb 17, 2007 04:31 PM
RACEPAK
10
Jan 14, 2005 01:45 PM
boosted jetta
Jul 7, 2004 08:11 AM
