help just wanted to know single v boosting
Old Jun 1, 2005 | 06:12 PM
jaydmegsix's Avatar
Default help just wanted to know single v boosting
if any has any answers i kind of know this one
i did a compression check on my car all cylinders are 180 except the number 1 its 152 how bad is that.
i thinking of putting my rev hard kit on how long will it last if im boosting 7lbs.
im probably going to do the rings and rod bearings though but getting anxious i just wanted in the rev hard kit.
ok guys put in new piston rings and rod bearings compression is good and no check engine codes fuel pressure at 38 to 45 new spark plug wires cap rotor spark plugs fuel filter, now i have a new problem my car feels like something is holding back
what do you think it could be?
oh yeah sometimes the car will pull like its suppose to but most of the time it doesnt
i was thinking maybe my fuel pressure regulator its the cheap aem or this might sound stupid my driver side brake line has a very small leak but enough to see the brake fluid come out i was thinking maybe the air it sucks back in could cause the brake to engage while im driving but who knows i sure dont
Modified by jaydmegsix at 12:58 AM 6/8/2005
Modified by jaydmegsix at 1:01 AM 6/8/2005
Old Jun 1, 2005 | 06:15 PM
s2kdre's Avatar
Default Re: help just wanted to know single v boosting (jaydmegsix)
theres no telling thats too far apart. You might be burnin oil in the cylinder.
Old Jun 1, 2005 | 07:11 PM
USDM 4G VTEC's Avatar
more than 10% variation between cylinders is the limit, anyting more, u want to do a leakdown test and see where the problem lies
i wouldnt boost that, it will bring bigger headacehs down the road
do it right the first time
i would be running 11's by now if i would have.... so learn a lesson
Old Jun 2, 2005 | 02:27 PM
jaydmegsix's Avatar
Default Re: help just wanted to know single v boosting (USDM 4G VTEC)
thanks guys
Old Jun 7, 2005 | 09:58 PM
jaydmegsix's Avatar
Old Jun 8, 2005 | 03:05 PM
jaydmegsix's Avatar
help
Old Jun 8, 2005 | 05:07 PM
Dunc's Avatar
BCICAN
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by USDM 4G VTEC &raquo;</TD></TR><TR><TD CLASS="quote">more than 10% variation between cylinders is the limit, anyting more, u want to do a leakdown test and see where the problem lies
i would be running 11's by now if i would have.... so learn a lesson</TD></TR></TABLE>
Please read the bold in the quote. You <U>definitely</U> want to do this. I just had this happen to me: compression was 175 across the board, but the leakdown showed a problem in #2. My guess is it was the rings, but I haven't seen them (the block was yanked and sent to ERL and I haven't been to the shop since so I can't say for sure that it was the rings).
Holy ****, I just re-read your post.....fix your break line THAT'S INSANELY DANGEROUS. Unless you like not having brake fluid to help you stop after a 4th gear pull
I doubt that it is your FPR. Yes they aren't the best, but a lot of people use them and never have any problems. Do the leakdown.
Old Jun 11, 2005 | 07:25 AM
jaydmegsix's Avatar
Default Re: help just wanted to know single v boosting (Dunc)
thanks
i rebuilt the bottom end and is running good now my timing was retarded too much thanks for the info guys
eternaltech
Nov 5, 2012 09:07 PM
slowwcivic
Dec 1, 2011 11:50 AM
ef9ridda
Apr 14, 2010 10:58 PM
egGSR_hi
May 16, 2009 12:23 PM
jaydmegsix
Jun 8, 2005 03:04 PM
