HeLp install wit the GM boost selenoid
Old Aug 4, 2003 | 06:48 PM
wade's Avatar
Default HeLp install wit the GM boost selenoid
jus got the gm boost selenoid
what the hell do i do wit it and my aem ems?
wade's Avatar
Default Re: HeLp install wit the GM boost selenoid (wade)
Old Aug 4, 2003 | 07:18 PM
salt's Avatar
its not too hard. hook one wire to 12v and the other to the correct pin on the ecu. then run the vacuum lines like in the diagram. I didn't get the C connector so I had to manually pin it to the ECU. I used a cut crushed end of a spade connector. The hard part is setting the wastgate duty tables + correction. I ended up getting a greddy profec A and using that. the 1.03 software seems to have better set up, but i'm still on v.94.
EARLdaSQUIRREL
Engine Management and Tuning
19
Apr 21, 2009 07:15 PM
greygoose
Feb 16, 2008 05:32 AM
GReddy SI
Sep 5, 2004 09:17 AM
JDM EX
May 5, 2002 09:48 PM
