help.....head gasket????
Old Jul 31, 2002 | 11:56 AM
integRated109's Avatar
Default help.....head gasket????
ok, car started overheating, threw a 73(misfire cyl 3) coolant was a little low, #3 plug was wet(looked like coolant) and white smoke from exhaust. compression test is a good 180 across the head(good for 9.5:1 pistons) im still tearinf stuff apart but it looks like a head gasket.....any other ideas? i thought a head gasket would show up on the compression test? coolant is clean, oil is clean and full.
Old Jul 31, 2002 | 12:17 PM
B20T's Avatar
Default Re: help.....head gasket???? (integRated109)
Check and see if there is bubbles coming out of radiator, also there some stuff that you can test if there is exhaust going into the radiator,it changes color if it does. GOOD LUCK.
[Modified by B20T, 3:17 PM 7/31/2002]
Old Aug 1, 2002 | 06:00 AM
IHaveTurbos's Avatar
Mike,
when did this happen? on the way to or from tahoe? send me an IM and let me know the deal.
Later, Tim
20civic01
Honda Civic (2001 - 2005)
Feb 22, 2014 03:39 PM
NubImports
11
Mar 10, 2009 08:34 PM
fdjizm
25
Mar 9, 2007 06:35 AM
gsrvtec2
Oct 16, 2005 12:14 AM
JTCdudeman
Sep 24, 2005 07:23 PM
