Help greddy 18g turbo replace
Old Jun 9, 2013 | 01:51 AM
datsun71's Avatar
Default Help greddy 18g turbo replace
looking for 18g turbo and haven't got any luck
Call greddy they said discontinued that turbo for
Honda
Is there any turbo that direct fit to greddy turbo kit for
B16a2
Thank
Old Jun 9, 2013 | 05:10 AM
grumblemarc's Avatar
The Grumpiest
Default Re: Help greddy 18g turbo replace
Any 18g should work shouldn't it?
Old Jun 9, 2013 | 06:49 AM
Casey's Avatar
t2/t25 inlet with 5 bolt internal gated exit should work. id get a gt28r or rs and have fun. if you cant or dont want to look into it further i may be interested in buying what you have
Old Jun 9, 2013 | 06:50 AM
TheShodan's Avatar
Moderator
No. most 18Gs are for the DSM in a Radius flange setup with a difference cartridge
The GReddy 18G is a mitsu/Garrett hybrid.
The best ones to fit are the GT2860RS, and GT2871R series turbochargers. However, the feed line and restrictors will need to be replaced, as well as the water lines that are required to use. The turbos in this family (especially GT2871R and GTX28 series) will be about 40lbs/min. You will still need to retune.
You can always attempt to have it rebuilt, as the cartridge set is mainly Garrett parts.
Old Jun 9, 2013 | 07:47 AM
nealnanoHX's Avatar
Yeah a good turbo rebuild shop should be able to rebuild your 18G, unless is got tot ally trashed.
Old Jun 9, 2013 | 09:14 AM
datsun71's Avatar
Plan to keep my greddy turbo kit
The don't know if the turbo can be rebuilt it
Leaking bad and the turbine not spinning
For the gt2871r will the greddy elbow directly fit
And do I need to custom a new downpipe
Will the greddy blue box work on the gt2871r
Old Jun 9, 2013 | 10:34 AM
komat's Avatar
http://www.sdforcedinduction.com/
email those guys. when i bought my 57trim from them. they had couple of them but it was a while ago
Old Jun 9, 2013 | 11:57 AM
datsun71's Avatar
Thank
Old Jun 9, 2013 | 12:05 PM
TheShodan's Avatar
Moderator
Originally Posted by datsun71
Thank
Which use different parts than what they have available. They use a straight Garrett cartridge GTR series turbine shaft sealing ring. But the thrust plate has to be custom shimmed to work. SD forced Induction aka. PureTurbo
Old Jun 10, 2013 | 11:01 AM
wantboost's Avatar
Who is Mr Robot?
You can always give me the 18g lol....
I have a journal bearing 2860 as well
datsun71
Jul 29, 2014 05:17 AM
horn12007
Jun 25, 2010 03:16 PM
civic-8442-
May 7, 2009 07:18 PM
OGI8UUP
Honda S2000
15
Jul 31, 2007 03:18 PM
KoRE
Jul 24, 2002 08:52 AM
