HELP !!!!!!! EXHAUST COMING OUT MY EXHAUST SYSTEM !!!!!!!
Banned
I DUNT KNOW HOW IT HAPPEN
I GOTZ ADVISE ON THESE MASSAGE BORED THAT I CAN BOOST 15 PSI ON GREEDY BLEU BOX ?
HELP!!!!!!!!!!!!!!!!!!!
New User
Re: HELP !!!!!!! EXHAUST COMING OUT MY EXHAUST SYSTEM !!!!!!! (immortal)
i think i read in another thread that you have a 8.8 JE PISTON and EAGLE ROD ? if that's the case, i think that's your problem! i have heard many instances a piston and a rod causing exhaust to come out of your muffler!
-Xerxes
-Xerxes
Banned
Re: HELP !!!!!!! EXHAUST COMING OUT MY EXHAUST SYSTEM !!!!!!! (falconGSR)
you're screwed. thats gonna cost a lot of beans.
what color is it?
what color is it?
clear smoke = running lean
black smoke = running rich
green smoke = coolant
blue smoke = smurfs
red smoke = fire
yellow smoke = low on intercooler oil
blue smoke = smurfs
red smoke = fire
Re: HELP !!!!!!! EXHAUST COMING OUT MY EXHAUST SYSTEM !!!!!!! (Xerxes)
i am positive you are detonating . One time i saw clear smoke and the next thing i know i beat a viper.
Re: HELP !!!!!!! EXHAUST COMING OUT MY EXHAUST SYSTEM !!!!!!! (dustin)
blue smoke = smurfs
red smoke = fire
blue smoke = smurfs
red smoke = fire
Has you muffler bearing fallen out yet?
Damn newbies J/K
funny!
Immortal,
Does this mean your new motor is finished?
Damn newbies J/K
funny!
Immortal,
Re: HELP !!!!!!! EXHAUST COMING OUT MY EXHAUST SYSTEM !!!!!!! (b18bturbo)
try 8.8 JE PISTON, EAGLE ROD.
if not that you should get a meguiars kit supercharged then turbo runs 4 lbs. of boost stock comression i'm sure this woudl do you right.
do you have OIL COMING OUT YOUR BLOW OFF VALVE???
p.s. do you run fuel?
this is usually cause by a failed piston return spring....you need to pull out your spark plugs and on the end of each one you will find a coil spring about 2inches long....check to make sure that each one has even, consistent tension....if these go bad it causes the piston to go down too slowly and send exhaust out of the exhaust pipe....when mine went bad it was because my water pump lubricant had become contaminated with intercooler oil....remember that you might need a left handed rachet to remove the springs from the spark plugs....hope that this helps.
steve
[Modified by seekerONE, 2:21 AM 3/1/2002]
[Modified by seekerONE, 2:23 AM 3/1/2002]
steve
Well
1. Check your IC oil, usually takes two quarts.
2. Check all your vaccum lines three of them should be leaking if not pucture holes in them
3. Take off your valve cover it the valvetrain is covered with oil, your screwed. Get a garden hose and wash off all the oil. You'll probally have to sand down your retainers and cams.
4. Check your tire pressure. if they are low, fill up to the appropriate psi with NOS.
5. If none of these things work. Turn the car on, cover the exhaust with anything, but make sure you hook up a hose that runs to the cab of your car. Sit in cab with the car on with the hose in there for about an hour. Let me know what color the exhaust is after that.
hahahahaha!!!
LOL!!!
hahahahaha!!!
LOL!!!
Re: HELP !!!!!!! EXHAUST COMING OUT MY EXHAUST SYSTEM !!!!!!! (turbocoupe)
i dont know if some of these replies are for real or not.. But I think you should check out your exhaust bearings. Those always go out on Hondas..
art
art
Re: HELP !!!!!!! EXHAUST COMING OUT MY EXHAUST SYSTEM !!!!!!! (Arturbo)
CLEAR SMOKE IS CAUSE THE EXHASUT ARE TO SMALL. DO WHAT I DID AND PUT ON GREEDY EXAHUST. ALLSO, SINCE YOU HAVE LS MOTOR, USE TYPE R CAMS IN IT FOR BEST PERFORMENCE. MAKES IT JSUT LIKE LS/VTECH.
Re: HELP !!!!!!! EXHAUST COMING OUT MY EXHAUST SYSTEM !!!!!!! (D-SPEED)
HELP I CAN'T FIGURE OUT HOW TO ADD OIL TO MY INTERCOOLER!!!!! AFTER READING THIS THREAD IT SAYS THAT MY INTERCOOLER NEEDS TWO QUARTS OF OIL. I PUT REDLINE IN THE BLOW OFF VALVE CAUSE IT SAYZ THAT IT WILL MAKE MORE POWER. THE PROBLEM IS THAT IT IS REALLY HARD TO HOLD THE BLOW OFF VALVE OPEN WHILE I POUR THE OIL IN!!!
PLEAZE HELP ME YO!
[Modified by FuzzyGreenCarpets, 3:30 AM 3/1/2002]
PLEAZE HELP ME YO!
i hear that if you sit in your car at leave it running with the garage door closed, you get neat dreams!
Re: HELP !!!!!!! EXHAUST COMING OUT MY EXHAUST SYSTEM !!!!!!! (1)
you need to clean your combustion chamber with TNT!! Do it quick or your car might die! Why are youstill reading this? Get to work fool!
