HELP!:Does O2 sensor ever go bad from being to close to the end of the Downpipe?
Old Sep 5, 2002 | 07:01 AM
SOUNDEFFECTS's Avatar
Default HELP!:Does O2 sensor ever go bad from being to close to the end of the Downpipe?
Stupid O2 sensor I believe went bad after I was driving in some hard rain the other day. I mean I have driven through worse before and nothing happened. Idle has been getting kinda low at idle the past couple weeks but didn't think anythign of it. I am under the impression that ots been clogged with dirt, oil, water, something?? Set off code 43 a couple times which is a FUEL SYSTEM code. Check Vaccum or FPR.
Everything is fine but I get no signal on my Air/Fuel Gauge. Its there for a second and then fades off. Just seeing if anyone had a problem like this before.
By the way O2 sensor is about 1/2 inch from opening of the DP(Very Open to the elements)
Old Sep 5, 2002 | 09:03 PM
B20C5 Turbo's Avatar
New User
Default Re: HELP!:Does O2 sensor ever go bad from being to close to the end of the Downpipe? (SOUNDEFFECTS)
Water destroys O2 sensors.
jayman3.0
Feb 3, 2008 05:07 PM
importdreamer
May 26, 2007 06:58 PM
SOHC4life 96
33
Oct 11, 2004 10:19 AM
IloveNewt
Mar 24, 2003 12:53 PM
quikrpm'z
Oct 10, 2001 06:15 AM
