help! d16z6 coolant plug.
Old Jan 18, 2016 | 02:24 PM
ahhwhat?'s Avatar
Default help! d16z6 coolant plug.
Hey guys, need help.
Almost done with my z6 turbo build.
I have 1 more thing to do. Looking for advice on getting the freeze plug welded. How is it suppose to look ? Want to show the machine shop, thanks.
Please post pictures!
Old Jan 18, 2016 | 03:42 PM
2kdrift's Avatar
Default Re: help! d16z6 coolant plug.
can you be more specific?
I assume you mean the freeze plug for draining coolant on the front of the block...why are you getting it welded? are you trying to attach some type of fitting to it?
Old Jan 18, 2016 | 05:38 PM
ahhwhat?'s Avatar
Yes, the freeze plug in front of the block. We are going to be running 25+ pounds on this motor. From what ive read the freeze plug is a weak point.
This is a sleeved z6 on Q. Thanks
Old Jan 18, 2016 | 06:00 PM
2kdrift's Avatar
freeze plug holds coolant not boost, Never had one come out on any motor but I wasnt running that much boost. Never heard of it being a failure point or anyone welding it. loctite if your that worried about it would be my only sugestion
Old Jan 18, 2016 | 06:18 PM
turbohatch96y7's Avatar
I think d series heads like to lift due to the shitty design and timing
Old Jan 18, 2016 | 08:15 PM
2kdrift's Avatar
Maybe im confused? the freeze plug im thinking of is no where near the head, its on the front of block
Old Jan 18, 2016 | 09:15 PM
When the head lifts where does All that cylinder pressure go?
Old Jan 19, 2016 | 04:10 AM
Kevinio's Avatar
He needs to weld that plug, otherwise the short blok will crack around the plug above 550whp.
Old Jan 19, 2016 | 04:48 AM
underrated's Avatar
Check out what speedfactory did
https://honda-tech.com/drag-racing-3...2921791/page2/
Old Jan 19, 2016 | 12:24 PM
ahhwhat?'s Avatar
thanks! yes this is correct.
just looking to see if anyone on hee has experience on this.
Old Jan 21, 2016 | 03:03 PM
cbustuner's Avatar
Something like that. I made that at work. I can try and find the dimensions. I made one that had more of a lip for someone else and it was harder to weld. I covered that spot in aluminum epoxy after the fact to ensure there wouldn't be any leaks
Old Jan 21, 2016 | 04:55 PM
ahhwhat?'s Avatar
Youre the man! this is what im looking for.
what kind of plug did you use? and where can i find it? thanks!
Old Jan 22, 2016 | 07:47 AM
Something like that.I made at work I can try and find the dimensions. I made one that had more of a lip for someone else and it was harder to weld. I covered that spot in aluminum epoxy after the fact to ensure there wouldn't be any leaks[/QUOTE]
97Integra
May 20, 2011 09:15 AM
vtecpoweredsol
May 19, 2005 11:20 PM
camera obscura
Jul 13, 2004 06:04 PM
Harry_Randal
May 23, 2004 03:00 PM
