help boosted wagon is overheating!
Old Sep 7, 2014 | 12:28 PM
  #26
TheShodan's Avatar
Moderator
Default Re: help boosted wagon is overheating!
Originally Posted by TheShodan
Oh.. that's right.. you're that guy that's gotta have last word on everything. I forgot about that..
Old Sep 7, 2014 | 12:33 PM
  #27
turbohatch96y7's Avatar
You're acting childish now.
Admit you were wrong telling the op to replace his headgasket.
And admit you don't know what the hell shimming a water pump means.
Its ok. We all make mistakes.
Old Sep 9, 2014 | 08:57 PM
  #28
89hybrid's Avatar
It seems as though I have stumbled into the middle of a school yard fight. Please boys kiss and make up.
Old Sep 9, 2014 | 09:10 PM
  #29
Blaze45's Avatar
Brrraaaap!
Hey OP, your car still overheating or what?
Old Sep 15, 2014 | 06:39 AM
  #30
natehumenberger's Avatar
Yes it's still overheating
Old Sep 15, 2014 | 07:06 AM
  #31
v8killaz's Avatar
your car is basically a stock d16 when not in boost, what you need to do is pressure test the cooling system...or that should have been the first thing you did.
if you have a good radiator, and pushing air(at the recommended temp), a good thermostat(run one please), and no leaks. then your car should not overheat unless you have air in system or warped/leaky head but that you would know from oil/water mixing
now go and check all those things and report back.
now if were talking boost then its probably just a **** tune. and wtf is 235hp at 17psi, is this vitara motor with eagles. how much timing are you running
Efjams24
16
Jul 3, 2012 07:37 AM
Fuzzy Rhubarb
Oct 3, 2007 10:26 AM
streetracerjoey210
Aug 18, 2006 09:49 PM
KeithGSR
Nov 19, 2004 02:45 PM
froggysquasher
Jun 19, 2004 12:00 PM
