help with boost controller
From: if you build it they will come, the bottom carolina, duh
hello,
i have a turbosmart manual boost controller and i was wonder how to hook it up. i already searched and couldn't find anything on how to hook it up. i was told that you hook 1 side to top of the wastegate(tial 38mm) and the other side to the compressor side of the turbo, but i tried that and it is just over boosting crazy, it hits the map sensor then overboosts. how do you hook it up.
thanks in advance
thanks in advance
Here are the instructions......
http://www.turbosmartusa.com/pdf/FG-GBCV-BT.PDF
It sounds like you are doing it right, so all I can think of is that either your hose is cracked, or the unit is defective.
