help with boost controller
Old Oct 22, 2005 | 12:14 PM
turbob16ef's Avatar
From: if you build it they will come, the bottom carolina, duh
Default help with boost controller
hello,
i have a turbosmart manual boost controller and i was wonder how to hook it up. i already searched and couldn't find anything on how to hook it up. i was told that you hook 1 side to top of the wastegate(tial 38mm) and the other side to the compressor side of the turbo, but i tried that and it is just over boosting crazy, it hits the map sensor then overboosts. how do you hook it up.
thanks in advance
Old Oct 22, 2005 | 12:18 PM
turbob16ef's Avatar
Default Re: help with boost controller (turbob16EF)
come on need help
Old Oct 24, 2005 | 07:22 PM
jrponline's Avatar
Here are the instructions......
http://www.turbosmartusa.com/pdf/FG-GBCV-BT.PDF
It sounds like you are doing it right, so all I can think of is that either your hose is cracked, or the unit is defective.
fourdoorturbo
Sep 26, 2008 08:51 AM
bodassy
Apr 16, 2008 01:41 PM
ericstambaugh07
Apr 7, 2007 12:45 PM
