Why am I making out injectors?
Iam running a lsvtec with a eBay kit at 8psi and I was maxing out 550cc injectors. So I ended up buying 1000cc injectors but when I dynoed my car I made 266whp @ 8psi
So I've heard dsm 440's should go up to around 300whp but I was maxing out 550's at 266whp. I tuned my car with uberdata and my aem and the dyno wideband read the same afr @ 11.5 in boost and good afr's in the all motor parts of the map so I can't figure out why I'm maxing out injectors so early. Oh yeah my fuel pressure was at 38psi but I was playing around with it in the map but it didn't make that much difference
Re: Why am I making out injectors?
how do you know you were maxing out the injectors? was the car going lean or was the software just displaying 100% duty cycle
38psi sounds low even for a stock fuel pump, are you using a 255pump, or oem, cause that could very well be your problem, if its a 255 pump and you were at 38psi then your pump is probly airating
don't ask how i know... cheap thing to replace = fuel filter. I decided to upgrade from 750cc to 1000cc injectors on dyno running into this problem thinking I was maxing out the injectors, and the 1000's didn't help... changed fuel filter and holy mother of god everything was so rich from us trying to add more fuel! I originally didn't think it would be the filter since it wasn't very old but live and learn!
you dont see it all to often, but it is a problem sometimes, restricted fuel filter is usually the first thing people assume it is, and its normally not, in your case you got lucky
deucedeuceEK
06-02-2007 04:33 AM
boostincoupe
12-15-2004 05:17 AM
