Help with APEXI filter (no adaptor????) (pics inside)
Old Mar 10, 2004 | 11:17 AM
-iLLuZioN-B18C1's Avatar
Default Help with APEXI filter (no adaptor????) (pics inside)
How would someone mount this on there turbo or even an intake?
I bought it a while back thinking that it was gonna be like a regular
filter with the rubber 'adaptor' piece so i could clamp it.
Old Mar 10, 2004 | 11:25 AM
igo4bmx's Avatar
a guy on another forum bought some rubber piece from the toilet section at a home depot...
he is on here (westcoaststyle)
Old Mar 10, 2004 | 11:57 AM
Cheivic's Avatar
Default Re: (igo4bmx)
I have the same thing except mine's a K&N. On the bottom it's not just open, there's a flat plastic plate with a square in the middle.
Old Mar 10, 2004 | 12:12 PM
psychotic_z's Avatar
Default Re: Help with APEXI filter (-iLLuZioN-B18C1)
Do the rubber plumbing thing. You need to fab up your own bracket or what not to make it fit your turbo or your intake pipe.
Old Mar 10, 2004 | 12:13 PM
igo4bmx's Avatar
Default Re: Help with APEXI filter (psychotic_z)
details!
Old Mar 10, 2004 | 12:16 PM
B18EG6's Avatar
Default Re: Help with APEXI filter (igo4bmx)
http://mkiv.com/techarticles/filters_test/2/
Old Mar 10, 2004 | 02:29 PM
KamikazeSol's Avatar
I had the same problem, but solved it by getting a cheap filter off ebay with an adapter that is for cars with a mass air flow sensor. You just have to redrill the mounting holes in the flange and then attach it to a turbo or intake with a silicone connector. I believe the one I bid on was for a Miata. Cost @20.00shipped.
Old Mar 10, 2004 | 03:57 PM
leadtrum's Avatar
Default Re: Help with APEXI filter (KamikazeSol)
yea they're all over onilne, usually around $30 bucks
Old Mar 10, 2004 | 04:06 PM
leadtrum's Avatar
Default Re: Help with APEXI filter (leadtrum)
also found this
http://www.ppeengineering.com/DIYSintake.htm
Old Mar 10, 2004 | 04:17 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by leadtrum &raquo;</TD></TR><TR><TD CLASS="quote">yea they're all over onilne, usually around $30 bucks
how would that work? woulnt it have to be rubber so you can clamp it?
Old Mar 10, 2004 | 05:24 PM
You could use the one in the picture. Just connect it to your hose with a silicone coupler.
Old Mar 10, 2004 | 05:30 PM
is that metal adapter 3"?
also, do they sell 3" hoses
Old Mar 10, 2004 | 05:44 PM
Cramerox's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by -iLLuZioN-B18C1 &raquo;</TD></TR><TR><TD CLASS="quote">is that metal adapter 3"?
also, do they sell 3" hoses</TD></TR></TABLE>
yes they do sell 3inch couplers
Old Mar 10, 2004 | 05:45 PM
Default Re: Help with APEXI filter (Cramerox)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Cramerox &raquo;</TD></TR><TR><TD CLASS="quote">
yes they do sell 3inch couplers</TD></TR></TABLE>
where can i get one?
Old Mar 10, 2004 | 05:47 PM
Cramerox's Avatar
http://www.roadraceengineering...s.htm
Old Mar 10, 2004 | 06:02 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Cramerox &raquo;</TD></TR><TR><TD CLASS="quote">http://www.roadraceengineering...s.htm</TD></TR></TABLE>
thanks
Old Mar 10, 2004 | 08:32 PM
B18EG6's Avatar
Default Re: Help with APEXI filter (B18EG6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18EG6 &raquo;</TD></TR><TR><TD CLASS="quote">http://mkiv.com/techarticles/filters_test/2/</TD></TR></TABLE>
crap im an idiot.. i meant to post this, im sorry.
http://mkiv.com/techarticles/a....html
Old Mar 10, 2004 | 09:07 PM
95excoupe's Avatar
I dont mean to steal your thread or anything but how much hp would you gain by changing the greddy filter to an apexi??
Old Mar 10, 2004 | 09:20 PM
http://mkiv.com/techarticles/a....html</TD></TR></TABLE>
LOL, i was wondering what point you were trying to get accross by posting that first link. thanks for the 2nd link
Old Mar 10, 2004 | 09:58 PM
ineedhelp's Avatar
i used an old intake filter as an adapter to save money.
what i did was:
1) cut the actual filter off an old intake filter. ( so now all you have is the metal plate and the rubber that comes with that intake filter.)
2) place the blue gasket you want to use over the flat metal piece of your old intake filter, and mark the holes.( i used the 4 bolt one)
3) drill the holes big enough for the supplied screws/bolts.
4) mount everything together, and screw in the screws/bolts.
5) fill up the edge where the apexi filter, and the metal plate connects with water resistent adhesive.
6) now all you have is your apexi filter mounted on the bottom half of your old intake filter, with the rubber piece so you can clamp it onto your pipe.
dont laugh at the electrical tape, i didnt have a clamp big enough at the time.
Modified by ineedhelp at 7:38 AM 3/11/2004
Old Mar 10, 2004 | 11:25 PM
Default Re: Help with APEXI filter (ineedhelp)
good stuff yall
thanks
Old Mar 11, 2004 | 03:27 AM
ATP Turbo sells all kinds of adapters. I ordered a 2.5-3.0 adapter since my intake on my turbo is only 2.5". It was @17.00 dollars.
Old Mar 11, 2004 | 03:31 AM
Default Re: Help with APEXI filter (95excoupe)
95excoupe,
It is not about increasing horsepower, but rather helping increase engine and turbo life. The Gredy filter has been proven to be garbage and the Apexi is one of the best on the market right now.
Old Mar 11, 2004 | 05:13 AM
leadtrum's Avatar
http://www.2kracing.com/produc.../2545
Old Mar 11, 2004 | 05:27 AM
Nextelbuddy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KamikazeSol &raquo;</TD></TR><TR><TD CLASS="quote">95excoupe,
It is not about increasing horsepower, but rather helping increase engine and turbo life. The Gredy filter has been proven to be garbage and the Apexi is one of the best on the market right now. </TD></TR></TABLE>
yea try telling that to all the dumb asses that run socks or panty hose with a hose clamp on their turbo crying that they have no room for a filter lol. i swear how gheto soem people are these days.
