help with AEM 3.5bar map sensor wire conections
Old Apr 4, 2005 | 10:47 AM
11seclude's Avatar
Default help with AEM 3.5bar map sensor wire conections
Hello, I have a bit of a problem here with the conections of my new map sensor.
First off do the wires that goes to the map sensor the same color code for all honda's reguardless of year? reason i ask is because I gave my cousin my stock map sensor with missing link and now I have a 3.5bar map sensor from AEM but the problem is that my egr valve sensor was disconnect also so now am confused because they both can plug into the egr valve with no resistance. on the first set of wires the wires are Green with white stripe,Red with white or yellow stripe kinda hard to tell then white with blue or looks to be black, again it's hard to tell, That's off the first clip.The second one is Yellow with Red stripe,Red with green stripe,Green with white stripe. the harness is from a 6gen accord but the motor is a h22a.
the AEM harness has a Red wire,white wire black wire. The wire that have no color is that the nutrul ground?
thanks in advance
Ryan559
Sep 2, 2012 08:46 PM
stpacura
Engine Management and Tuning
Aug 8, 2008 10:35 PM
B!^A@
Nov 23, 2006 12:13 PM
Gant
May 18, 2005 08:47 PM
xXx Justin xXx
Jun 18, 2003 09:49 AM
