helicoiled headstuds and high boost.....
Old Mar 2, 2006 | 08:42 AM
caspers_hatch's Avatar
Default helicoiled headstuds and high boost.....
I am looking into buying a block that may need to be helicoiled for 1-2 headstuds. Its a sleeved block and i hope to make 400 whp with it, will the heli-coils present a problem with the headgasket holding up?
TIA!!
Old Mar 2, 2006 | 09:23 AM
_BEN_'s Avatar
Default Re: helicoiled headstuds and high boost..... (caspers_sfwd)
Helicoils are pretty damn strong.
The only thing I would be worried about is if there is enough material around the area you will have to drill and tap.
Old Mar 2, 2006 | 10:06 AM
Antilag's Avatar
Default Re: helicoiled headstuds and high boost..... (_BEN_)
woah, the helicoils do not hold up well. Do a search. You want a solid insertplug. The timecert is the only way to go IMO. I had to do 4 on my wifes built motor. The head studs held with zero problems. Ran all season 22-25 psi 454 whp. I have heard many times of the helicols failing. Do a search on how to get the kit and install it .
You want the 1inch slugs not the 1/2 inch.
X-Mazda 3 Racer's Avatar
DO NOT HELI-COIL THE HEADSTUDS! Use a Time-Sert. They are MUCH better than a heli-coil!
Old Mar 2, 2006 | 11:04 AM
Default Re: helicoiled headstuds and high boost..... (Mazda 3 Racer)
Thanks. I just wanted to make sure i could make use of it.
Old Mar 2, 2006 | 11:45 AM
80884's Avatar
1/2" headstuds. If you know a good machinist. Thats the way I fixed three messed up holes in my block. Fix and an upgrade all at one time.
bosted coupe
Dec 16, 2010 06:29 PM
beater1
Jul 25, 2008 08:13 AM
jarven093
Apr 13, 2007 10:59 AM
jarven093
Apr 13, 2007 09:47 AM
94TealGSR
Feb 8, 2003 08:39 AM
