Heat problem with MSD?
Old Nov 3, 2003 | 07:08 AM
skrewdlude's Avatar
Default Heat problem with MSD?
Hey guys,
I have been having some heat problems with my turbo prelude for a while now, and I always thought it was becasue the intercooler was blocking my radiator. I recently figred out that with my MSD Digital 6 out of the car, the car runs much colder. normally in traffic with the digital 6 and ss coil, the car gets up to 100 degrees celcius. Without the ignition the car barly gets to 90 celcius if it even gets that hot. I will probably take the ignition out when I retune the car, but can anyone help me understand why it is doing this? I have NQK wires, digital 6 plus, SS coil, and NGK bcpr7es plugs gapped to .040.
Thanks,
Josh
Old Nov 3, 2003 | 07:17 AM
PrecisionH23a's Avatar
Default Re: Heat problem with MSD? (skrewdlude)
It sounds like when the ignition is installed your timing is too far advanced. If you are boosting then I recommend you gap your plugs down to a .030-.032.
Old Nov 3, 2003 | 07:32 AM
skrewdlude's Avatar
Default Re: Heat problem with MSD? (GudeH23a)
cool man, I will try that before I pull it out. How much should I pull my timing?
Thanks,
Josh
Old Nov 3, 2003 | 07:44 AM
Is it running hot when you boost? I recommend you gap your plugs down to a .030 to .032 before you mess with timing and see what happens.
Old Nov 3, 2003 | 07:54 AM
skrewdlude's Avatar
nope, when I am driving it cools down prety quickly. Even when boosting.
It is just when at a stop that it does this.
Old Nov 3, 2003 | 07:57 AM
Are your fans coming on at all? Have you checked? If they are, my bet is the ignition is advancing your timing too much. I had this problem a few years ago when I did not run the gm 3 bar map sensor to retard my timing under boost.
Old Nov 3, 2003 | 08:55 AM
skrewdlude's Avatar
yea, the fans are coming on when they are suppose to. I could understand this if it was overheating while boosting, but it isn't. It is only when stopped or barly moving(not boost).
Josh
Old Nov 3, 2003 | 09:00 AM
30psi Teg's Avatar
Just a thought but you should check and make sure you have good grounds. I remember a friend of mine had a problem similar to this and come to find out it was just a bad ground. So possible the ignition is creating ground noise and inconjuction with a bad ground the gauge is reading strangly.
Just a thought
crazyrida
Sep 19, 2007 02:10 PM
s2kkid
Jan 25, 2006 08:17 AM
^jefs0ng
Oct 28, 2003 02:53 PM
Smith Wise
Feb 17, 2003 10:15 AM
