Headgasket Vote
Old Sep 5, 2003 | 07:33 AM
mister2racer's Avatar
Default Headgasket Vote
Building a early closed deck h22 with bensens sleeves, bensen decided to o-ring my block. Forced induction very high HP application.
Should I go with stock headgasket, cometic headgasket, or other?
Thanks,
Charles
Old Sep 5, 2003 | 07:49 AM
DaveF's Avatar
Default Re: Headgasket Vote (mister2racer)
stock with copper spray.
Old Sep 5, 2003 | 07:57 AM
SpoolnG2's Avatar
Default Re: Headgasket Vote (2.2Lcivic)
if your motor is bored out at all, i reccomend getting a Cometic. They make different bore sizes for the motor. they are also high quality and do a good job.
Old Sep 5, 2003 | 08:43 AM
VTEC-DA's Avatar
Default Re: Headgasket Vote (SpoolnG2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SpoolnG2 &raquo;</TD></TR><TR><TD CLASS="quote">if your motor is bored out at all, i reccomend getting a Cometic. They make different bore sizes for the motor. they are also high quality and do a good job.</TD></TR></TABLE>
You can also get an OEM gasket bored out to fit the motor.
Old Sep 5, 2003 | 08:48 AM
due to my high HP goals, and the fact that its already a 2.2L engine... I went with a 87mm CP piston. So stock headgasket would be suitable still.
I come from the Toyota 3SGTE world, where headgasket problems are easily obtainable if you dont do **** perfect the first time. The headstuds are larger on the H22 than they are on my 3SGTE. I was always told not to use o-rings with a steel headgasket?
If its working for other people than I would not be affraid to try it at all. It wouldnt be the end of the world but I really really would prefer not to have to do it twice.
Any other opinions? Thanks everyone so far!
-Charles
Old Sep 5, 2003 | 09:02 AM
SpoolnG2's Avatar
Default Re: (mister2racer)
i have a benson sleeved and o-ringed block, and i used a cometic gasket and did have a problem. they make 2 gaskets, one with copper in them and one without. if u allready have a copper o-ring then u will need the other one.
Old Sep 5, 2003 | 09:37 AM
drvfast's Avatar
stock
nengx07
Feb 3, 2009 08:43 PM
MadVTI
Jan 31, 2009 08:14 AM
turbotime
Oct 12, 2005 08:04 AM
Turbocivic94
Apr 25, 2005 06:21 PM
