Headgasket Question?
Old Oct 20, 2004 | 07:20 PM
99Sivic's Avatar
Default Headgasket Question?
is it true that you can lower the compression on an engine by putting in a thicker headgasket. If so im running at 6lbs of boost. How much more boost would i be able to run. And at where could i get the gasket.!
Dont Mind the newby question..!
Old Oct 20, 2004 | 07:22 PM
XxRoCkMaNxNEOxX's Avatar
Default Re: Headgasket Question? (99Sivic)
it is true. you will hear most people prefer going w/ stock headgasket w/ pistons and rods, but there are plenty of people running one bar w/ a thicker headgasket. u can buy inlinepro or the cometic one.
Old Oct 20, 2004 | 07:36 PM
NVturbo's Avatar
O.G. triple O.G.
I bought my Cometics MLS headgasket from Race Engineering. They are out of Florida and they usually keep these in stock for Honda engines.
Old Oct 20, 2004 | 07:59 PM
PrettyLude's Avatar
inline pro
Old Oct 20, 2004 | 08:08 PM
HotRodTeg's Avatar
Default Re: (PrettyLude)
Ive never seen or installed a aftermarket thicker head gasket yet, But Ive done up to 11psi on a stock b16 motor on pump gas with Hondata and it held up fine. Just be conservitive with timing up there. Good luck.
Old Oct 20, 2004 | 08:47 PM
99Sivic's Avatar
Default Re: (CrazyCompression)
Thanks for all the insight....gonna look into them. But has anyone on H-T. actully used them. what would be the max PSI that i could get. NOT that i would run that just for then information reasons.
HT Username
May 11, 2005 09:29 AM
Vampyre
Apr 17, 2003 08:52 PM
turbochic
Mar 29, 2003 06:32 PM
BlackGSR
Jul 15, 2002 02:10 PM
Charles B.
Oct 29, 2001 09:26 AM
