headgasket problems
Old Oct 18, 2008 | 07:15 PM
lowerd_rs's Avatar
New User
Default headgasket problems
so i just boosted my car b16a cast manifold, precision sc63 turbo, 1000cc injectors, cams , valves retainers, 9:1 pistons, eagle rods and stock head gasket. i made 280hp on 11lbs but blew the headgasket before it was fully tuned. i took it home and put a new gasket in the tuner told me to break it in a bit so i did. 1 week later my headgasket goes again does anyone know what this could be from or if i should use a better gasket
Old Oct 18, 2008 | 07:44 PM
blinx9900's Avatar
Default Re: headgasket problems (lowerd_rs)
when you say stock headgasket you mean OEM from honda? If so those are AWESOME! the stock HG has been proven to hold a lot of power, now, do you have headstuds, if so are you torqueing them properly with the lube provided in the poper sequence?
did you get your block decked and head resurfaced when you did the motor?
RoBsReX88
Feb 20, 2013 07:46 AM
JDM_SOHC
Aug 10, 2007 04:09 PM
boosted92
Jun 9, 2005 02:32 PM
Lmgrcivic
Feb 6, 2005 04:55 PM
boostedcivicsir
Mar 26, 2003 04:30 PM
