header wrap good or bad???
Old Dec 7, 2002 | 10:18 PM
delux247's Avatar
Default header wrap good or bad???
i was told by a friend that using header wrap will cause my turbo manifold to crack
is this true has anyone used it
please help
thanks
Old Dec 7, 2002 | 10:23 PM
Cramerox's Avatar
Default Re: header wrap good or bad??? (egcivicturbo)
wont crack if its a good manifold and made from SS
Old Dec 7, 2002 | 10:24 PM
ninesecrx's Avatar
The most important run on the header is the first 3 inches comming off the head. This is where you want the most smooth transfer and to keep the heat energy the highest. All you need to do is wrap the fist few inches and it shouldnt make it crack. Although over a long period of time if the entire mani. was wrapped, it does increase the chances of it cracking.
sutrusu's Avatar
it's good because hotter exhaust flows faster. which equates to quicker spool up. probably not noticible though. and i dont know about cracking, do you have a tubular manifold? or log style?
Old Dec 7, 2002 | 10:26 PM
delux247's Avatar
Default Re: header wrap good or bad??? (sutrusu)
my manifold is tubular and stainless steel
Old Dec 8, 2002 | 08:51 AM
delux247's Avatar
any more comments???, thoughts or theories
Old Dec 8, 2002 | 10:11 AM
civictypenos's Avatar
i just like it beacuse it keeps the temps down under the hood,i used alot of it on my downpipe,i can almost hold my downpipe after a run and not burn my hands.when i was N/A i had it on my comptech SS header,after i removed it it left scares from the wrap,couldnt sand them out,so it does do a little damage but not too bad.i just had my manifold jet coated and my downpipe wraped, and put the reflective heat stuff on my intercooler piping.
boostedblack99
Feb 17, 2005 10:56 PM
RUBZERK
Apr 2, 2004 11:09 PM
f@sth@tch89
Jul 18, 2003 09:31 AM
sleeepy
Apr 3, 2003 01:42 PM
glagola1
Mar 26, 2003 12:20 PM
