header wrap...
Old May 24, 2004 | 06:06 PM
mildly.interesting's Avatar
Default header wrap...
I know there are a few threads with this in it, but not exactly what I was looking for. I'm getting ready to wrap my manifold and downpipe, and I might do my cold charge pipe...
I wanna see some pictures so I'll know kinda what it's supposed to look like...TIA!
Old May 24, 2004 | 07:12 PM
TurboBumblBee's Avatar
Default Re: header wrap... (mildly interesting)
just start wrapping.. not very difficult to do.. i used some hose clamps to keep the wrap in place on the start and finish of the wrapping..
Old May 24, 2004 | 07:16 PM
cool, I thought it would be that easy, but you never know...
Old May 24, 2004 | 07:19 PM
Default Re: (mildly interesting)
wait a minute and ill get a pic of my downpipe.. im uploading some pics and found this one..
*edit..
here you go
Modified by Boostfedb18c1 at 11:30 PM 5/24/2004
Old May 24, 2004 | 07:20 PM
Default Re: (Boostfedb18c1)
thanks man...
Old May 24, 2004 | 07:23 PM
Drew Peacock's Avatar
You are meant to over wrap the previous piece by about a third of its width for a decent result, I over wrapped mine by 50 % and am happy, get some hose clamps for your mani.
Old May 24, 2004 | 07:28 PM
do you think it's possible to wrap a mani still on the block? My DP comes off easy, but it's tight around the manifold, and it makes it a bitch to take off...
Old May 24, 2004 | 07:32 PM
depends on the manifold.. just take your time.. i dont have my mani wrapped cause i have a drag log manifold but one day down the road i will have an equal length manifold
Old May 24, 2004 | 07:33 PM
cool
Old May 24, 2004 | 07:35 PM
I did mine in the pic above still attached helps to have a friend about though, used like 50 feet
Old May 24, 2004 | 07:38 PM
I got a 100 ft roll of 2 inch from some marine store, so I hope it's enough...mechanics wire or hose clamps to hold it on?
Old May 24, 2004 | 07:44 PM
SIXTYdashONE's Avatar
HT's Biggest Loser
Pretty Self explanatory buddy..
Old May 24, 2004 | 08:49 PM
IN VTEC's Avatar
Wrap it snug and pull it time every pass you make. If you have to make a weird bend, you can put a fold in the wrap so that it makes the tighter radius of the bend go smoother.
Use a zip tie to temporarily secure the finishing end if you can't get a hose clamp in there easily enough while at the same time keeping tension on end of the wrap.
Old May 24, 2004 | 09:19 PM
egturbo's Avatar
yeah imma bout to do the same thing.. lets see pics. \
is it gonna be hard to wrap this old school rev hard mani? and i have like a big *** roll of a hundred feet do i cut some off then start? what if i come short lol.
Old May 25, 2004 | 07:42 PM
-iLLuZioN-B18C1's Avatar
Default Re: header wrap... (egturbo)
to those who have done this. im not exactly sure how much it reduces underhood temps, but is it enough to make a noticable difference in power (im refering to your butt dyno )as the result of the engine bay being cooler?
Old May 25, 2004 | 07:46 PM
absolutely...
Old May 25, 2004 | 08:04 PM
Default Re: header wrap... (-iLLuZioN-B18C1)
Meh not really noticable on the butt dyno in my case, it definitely was worth doing however for the practical reason of being able to touch the mani when its hot without leaving your skin behind on it..
Old May 27, 2004 | 05:59 AM
Default Re: header wrap... (turbozxi)
is the wrap sticky on one side so itll stay on the manifold? if not what do yall do to keep it in place. also, how many layers do yall wrap it.
Old May 27, 2004 | 06:33 AM
MiraiZ's Avatar
wear gloves too...I got that **** on my hands and it stinged for days!
Old May 27, 2004 | 08:09 AM
Turbo E's Avatar
its a fiberglass fabric wrap, thats why it itches.
i use aluminum ire to tie it down easier to cut off than unscrew a clamp. also if your wrap has a sticky side, you bought the wrong one. what you bough is heat shield wrap, to keep out heat. (shiny silver on one side.)
you want the ones like the ones pictured, dull tan on both sides, NO glue
BTW it will smell and smoke a bit on the first start up
Old May 27, 2004 | 09:05 AM
thenick's Avatar
Default Re: (Turbo E 604)
is this harmful to do to the manifold seeing as how it contains heat? i've read that the N/A guys won't do it to their headers unless they're cast iron like the JDM ITR one or else it'll crack.....anyone experience cracking manifolds as a result?
Old May 27, 2004 | 10:51 AM
Alstare's Avatar
Default Re: (ixiblindixi)
Also, not mentioned yet...
Usually you get this stuff damp before putting it on, then once your all done, when it dries it pulls itself tighter and seals up nicely..
Made a huge heat difference when I put it on, my hood used to be hot to the touch before it, then after i could put my hand on the manifold after hard driving.
I plan on wraping my new manifold ASAP...
Old May 27, 2004 | 12:10 PM
tthame1's Avatar
Default Re: (Alstare)
Yeah, I've heard that this stuff will cause whatever you wrap to crack b/c it hold so much heat in. I'm kind of scared of wrapping my stuff.
Old May 27, 2004 | 12:42 PM
Default Re: (tthame1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tthame1 &raquo;</TD></TR><TR><TD CLASS="quote">Yeah, I've heard that this stuff will cause whatever you wrap to crack b/c it hold so much heat in. I'm kind of scared of wrapping my stuff.</TD></TR></TABLE>
ive heard the same. any input from those who have had it on for a long time?
Old May 27, 2004 | 12:51 PM
hpfsi's Avatar
Default Re: (-iLLuZioN-B18C1)
Zero problems with cracks, but it fucked up the polished finish on my header like you wouldn't believe.
