head stuck help!
Old Aug 9, 2012 | 08:26 AM
Crazy_SI_T's Avatar
Default head stuck help!
found this little fitting thay goes in the block thay controls oil pressure on the cylinders. ( why it was removed is beyond me). I got everything unbolted but the head will not budge, i can get all corners to start to lift except the alternater corner one. Ice tried prying it off but endes up snapping a 3/4 wrench in half.
Any suggestions would be great.
Old Aug 9, 2012 | 08:35 AM
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
Default Re: head stuck help!
Remove the last bolt... It is almost impossible for it to be that stuck unless you are missing something. Also, get your head checked because if you are breaking wrenches, there is a possibility you have damaged it.
Old Aug 9, 2012 | 08:50 AM
jdm_h22's Avatar
Lolz
Old Aug 9, 2012 | 09:28 AM
Dc4LsTeG's Avatar
EK9
Your missing something. What engine? Why are you trying to pry it with tools? You'll be very lucky if you didn't mess anything up
Old Aug 9, 2012 | 09:49 AM
Crazy_SI_T's Avatar
The point im prying it is on the backside with a spot that hangs over
Old Aug 9, 2012 | 09:56 AM
Dc4LsTeG's Avatar
EK9
Well to pry it you have to be putting the tool against the block or head surface which isn't good either way. What engine? Arp head studs?
Old Aug 9, 2012 | 01:05 PM
Crazy_SI_T's Avatar
Got it handles. My dumb *** forgot a nut. Erase thread
Old Aug 9, 2012 | 06:50 PM
DO IT ON ALL FOURS
Originally Posted by jdm_h22
Lolz
What? As usual I was right.
Old Aug 9, 2012 | 07:02 PM
Hidenplanvew's Avatar
hahaha
RSSEXtype-sizzle
Aug 12, 2012 09:46 PM
sanman000719
Jan 22, 2011 04:59 PM
natzimus
Apr 27, 2006 06:04 AM
Turbo_y8
Feb 25, 2006 10:10 PM
jizzer671
Jun 8, 2005 03:40 AM
