Head separating from block
Old Jul 4, 2003 | 11:53 AM
SuzukaBlueAP2's Avatar
Default Head separating from block
anyone ever experience this ? My integra has done this on 2 occasions now...1st time, it cause me to cook my bottom end. I caught it this time, but i don't know why it's happening. Ever since i boosted my Teg, it will run fine for just a short while, maybe a day, and then all of a sudden it's a wave of oil shooting out the back of the head where it meets the block. This is at 7-8 psi. anyone know why ?
Old Jul 4, 2003 | 11:54 AM
rjardy's Avatar
Default Re: Head separating from block (urbanracer98)
I think that your head is probably warped, have you had it decked?
Rob
Old Jul 4, 2003 | 11:57 AM
Default Re: Head separating from block (rjardy)
well, I hope that isn't the case. Because this second time, I got a Jasper engine, and it comes fully assembled from the cams down.
Old Jul 4, 2003 | 12:31 PM
b18bturbo's Avatar
what gasket did they use what what head studs any machining done to both surfaces.
It could be possibility your head is not sitting flush down to the deck of the block.
the actual dowels might be too long. its possibility. Do they use factory gaskets or do they use aftermarket
Old Jul 4, 2003 | 12:37 PM
Default Re: Head separating from block (b18bturbo)
They use all OEM parts. I've had one of their engines before in a Blazer, and it ran awesome. Never had one problem with it. I've seen videos of footage of thier rebuild processes and such. And it's amazing how much treatment they go through. Every clearance, spec, and adjustment is checked over and over again.
All material is OEM Honda. I'm just wondering if maye I jumped on my motor too soon and actually forced the head to lift up a little bit. Is that possible ? If so, would it be possible to tighten the head studs ? or put new ones in, possibly ARP studs ?
Old Jul 4, 2003 | 12:38 PM
b18bturbo's Avatar
i would probably pull the head take it to reputable machine shop check it for warparge then also check the dec ksruface and put a new gasket with some ARP head studs you should be fine
Old Jul 4, 2003 | 12:40 PM
I'm hoping....this is getting to be a bit more costly than what's it worth.
Old Jul 4, 2003 | 02:02 PM
anyone else have any ideas while this is out here?
Old Jul 4, 2003 | 02:49 PM
rjardy's Avatar
im allmost 99% sure like I said before,your head is warped...
Rob
Old Jul 4, 2003 | 03:14 PM
bxsi's Avatar
ethier your head is warped and needs to be milled or your head gasket might have warped and needs to be replaced. try a leakdown test first.
Old Jul 4, 2003 | 03:15 PM
bxsi's Avatar
just read your post again i didnt read that it happened twice alrady, i'm gonna say the head is warped or the dowels need to be shaved down some.
weekendboost
Apr 18, 2014 04:45 AM
K20teggg95
Oct 22, 2011 10:41 AM
jr12
Apr 19, 2007 05:44 AM
RACING INTEGRATION
May 22, 2006 03:31 PM
Space Boy
Oct 1, 2003 10:49 AM
