What do i do with a stripped head bolt??
Subscribe
Apr 20, 2003 | 11:50 AM
is there ANY way I can get the head bolt off when it's partially stripped? i don't want to strip it anymore... stupid craftsman socket cracked so it stripped it partially... please help.. thanks
Reply 0
Apr 20, 2003 | 12:35 PM
Re: What do i do with a stripped head bolt?? (accordfreak)
The head of the blot? or the threads on a stud?
Reply 0
Apr 20, 2003 | 12:37 PM
Re: What do i do with a stripped head bolt?? (B18EG6)
oopss.. the head of the bolt.. thanks!
Reply 0
Apr 20, 2003 | 12:40 PM
You can try going one size smaller and jam it in there to take it out.
Reply 0
What size socket are you using? And did you manage to unscrew it at all?
Reply 0
Apr 20, 2003 | 01:10 PM
dremel it to a smaller size sometimes works
Reply 0
Apr 20, 2003 | 01:12 PM
Re: What do i do with a stripped head bolt?? (94goldjungsr)
vice grips
Reply 0
Apr 20, 2003 | 02:14 PM
Re: What do i do with a stripped head bolt?? (GottaLude)
are you using a 6point 14mm
Reply 0
Apr 20, 2003 | 02:57 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GottaLude &raquo;</TD></TR><TR><TD CLASS="quote">vice grips</TD></TR></TABLE>
I dont think you can use vise gripd on the headbolts, they are recessed in the head.
were you able to loosen it at all before stripping it?
Reply 0
Apr 20, 2003 | 07:23 PM
yeah i was using a 6pt 14mm and it snapped which kinda stripped the bolt... and now i'm afraid it'll be stripped completely if i try again.
i was only to loosen the bolt a 1/4 a turn
the dremel the bolt idea is great! i think i'll try that.
anymore inputs before i do?
thanks!
Reply 0
Apr 20, 2003 | 09:57 PM
craftsman has a reverse socket kit for like 20bucks
Reply 0
Apr 20, 2003 | 10:11 PM
i think craftsman has a stripped bolt remover i did that to on e fo the headbolts i stripped it came right out with no problems
Reply 0
Apr 21, 2003 | 02:09 AM
Re: What do i do with a stripped head bolt?? (Giovannie)
thanks for your replies! i will check out sears soon!
Reply 0
Apr 21, 2003 | 03:39 AM
If i;m not mistaken the headbolt take 13mm 12 points socket.
Reply 0
Apr 21, 2003 | 11:53 AM
Re: What do i do with a stripped head bolt?? (Ltech)
nah it's a 6pt 14mm bolt.. i tried the 13mm 6pt.. too small
Reply 0
Apr 21, 2003 | 06:36 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by accordfreak &raquo;</TD></TR><TR><TD CLASS="quote">nah it's a 6pt 14mm bolt.. i tried the 13mm 6pt.. too small</TD></TR></TABLE>
go to sears and ask them for the stip bolt remover i beelive it comes in a set of 10mm to like 17 mm its about 20 bucks use it and return thats waht i did
Reply 0
Apr 21, 2003 | 09:21 PM
.<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Giovannie &raquo;</TD></TR><TR><TD CLASS="quote">
go to sears and ask them for the stip bolt remover i beelive it comes in a set of 10mm to like 17 mm its about 20 bucks use it and return thats waht i did</TD></TR></TABLE>
Slick *** move I'll remember to do that in the future
Reply 0
Apr 21, 2003 | 10:21 PM
Re: What do i do with a stripped head bolt?? (roydogg)
Get the metriwrench set! Dont knock it till you tried it cause it saved my *** a few times when the craftsman sockets didnt want to grab.
Reply 0
Apr 22, 2003 | 12:22 PM
Reply 0
Apr 22, 2003 | 12:34 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Giovannie &raquo;</TD></TR><TR><TD CLASS="quote"> </TD></TR></TABLE>
those stripper removers works great.. i have set here as well they are 17.50 at local sears.
Reply 0
Apr 22, 2003 | 01:29 PM
Re: What do i do with a stripped head bolt?? (b18bturbo)
AWESOME! thanks guys! time to get a set!
Reply 0
Apr 22, 2003 | 01:37 PM
next time use a impact socket to take head bolts out. Those sockets dont give for anything and your not gonna snap em either...if you do your more of a man than i am
Reply 0
Subscribe
