head gasket question with boost
Old Mar 19, 2002 | 08:51 AM
turbotec's Avatar
Default head gasket question with boost
http://www.f-max.com/Detonation%20Management-Honda.htm I was reading this page, and if you go down to the headgasket part, they are saying that if you put on this headgasket, you dont need to mess it the timing at all up to 13 psi on stock applications. is this true?? what have you guys dealt with?
Old Mar 19, 2002 | 09:46 AM
ATurboCivic2NV's Avatar
Default Re: head gasket question with boost (turbotec)
i am sure if you read a little more that is not on pump gas. they are using an octane booster!!
Old Mar 19, 2002 | 02:06 PM
turbotec's Avatar
Default Re: head gasket question with boost (ATurboCivic2NV)
yeah but they are saying that is on 92 octane gas, which is the supreme gas. I run the 92 octane already. if that is the case, I definately want to get one. im only going to run a max of 8 psi. probably 6 psi mostly. just want to know what kind of timing issues I will have
LightWeightChamp
Dec 11, 2008 07:48 AM
Boost2NA
Sep 30, 2003 02:55 AM
FalconMan
Mar 4, 2003 10:12 AM
shadowdawn
Nov 6, 2002 10:45 AM
slowcivic
Oct 14, 2001 11:12 AM
