head gasket maybe
Old Nov 3, 2007 | 07:38 AM
panda_eh2's Avatar
Default head gasket maybe
my setup is a 95 gsr with eagle rods and je pistons arp head studs honda head gasket, stock head. msd 6al ignition s300. i have been having a problem with my coolant lines exploading for the past few weeks and i hardly ever drive the car. when i had the motor bored i had the head decked. i just replaced the head gasket because i was told this was the problem and it fixed it for about 3 days. at first i thought it was the cometic .051 gasket i had, and i took apart the head to retourque it down and the head studs were really loose. i tightened them down to 80lbs and ended up replacing the gasket 3 days later because it didnt fix it. i put a funnel in the radiator and filled it with water and i can see bubbles comming out, and when i rev the motor a little bit they get worse. does anyone know the problem. maybe my head is warped.
Old Nov 3, 2007 | 07:43 AM
integraRS-T's Avatar
it sounds like ur head is warped,take a straight edge across the head and find out
Old Nov 3, 2007 | 07:47 AM
panda_eh2's Avatar
could it be that when i got it decked like 2 months ago they didnt do it right? what do you guys think about a b16 head on my gsr block?
Old Nov 5, 2007 | 10:08 AM
panda_eh2's Avatar
help
Vtec04
Engine Machining & Assembly
11
Oct 31, 2017 09:26 AM
hawaii_boi_808
Jun 20, 2008 09:17 PM
downeyballz
Sep 26, 2007 08:44 PM
Dartanian
Jun 13, 2006 10:40 PM
92hatchattack
May 5, 2004 06:08 PM
