head gasket compression?
Old Aug 24, 2003 | 05:30 PM
rocket256's Avatar
how far will a 3mm head gasket lower my compression?
if the compression is 10:1!
Modified by rocket256 at 2:20 PM 8/25/2003
Old Aug 24, 2003 | 06:09 PM
TurboJesse
Guest
Posts: n/a
Default Re: head gasket compression? (rocket256)
Im running an inline pro 3mm headgasket, i believe it drops the compression down 1 pt, i could be wrong though.
Old Aug 24, 2003 | 06:16 PM
rocket256's Avatar
Default Re: head gasket compression? (Mpir3)
how many psi are you running?
Old Aug 24, 2003 | 06:29 PM
TurboJesse
Guest
Posts: n/a
i still have to get tuned (hondata) I plan on running 12-14 on 94 and 15-16 on race.
Old Aug 24, 2003 | 06:34 PM
rocket256's Avatar
right on! what type of kit is it?
Old Dec 31, 2003 | 05:39 AM
mrx's Avatar
mrx
i don't think that it drops the cr only by 1 pt... i also have a 3mm plate and my cr ist 7.7:1 .... original was 10.2:1
Old Dec 31, 2003 | 06:55 AM
m R g S r's Avatar
Default Re: head gasket compression? (mrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mrx &raquo;</TD></TR><TR><TD CLASS="quote">i don't think that it drops the cr only by 1 pt... i also have a 3mm plate and my cr ist 7.7:1 .... original was 10.2:1</TD></TR></TABLE>
I really doubt that it drops it that much, I think it's around 1pt.
Old Dec 31, 2003 | 06:59 AM
Boostfed's Avatar
New User
If it is a 3mm headgasket that equals .11811 inches, original GSR motor at 10:1 then with this gasket I calculate 8.2962:1 WHOAH! I think the 3mm askets are meant for the ITR motors of 10.6:1 and 11:1 JDM ITR. The 2mm gasket on your 10:1 motor would put you at 8.9624:1 so very close to 9:1. Your sig says JDM GSR motor, if so and no chanes that is a 10.6:1 CR motor.
texx
Honda S2000
Aug 27, 2006 06:17 AM
vtekthis
Nov 2, 2004 07:17 PM
fastludeh22
Oct 14, 2002 01:52 PM
