head gasket on backwards?
Old Aug 2, 2002 | 12:03 PM
syeve's Avatar
Default head gasket on backwards?
is there any way to tell if my headgasket is on upside down....my car keeps overheating and that is like he only thing I have not checked but i dont want to rip my head off...Im running a 3mm greddy copper on a D16...any way to check? I can take pics if that will help.
[Modified by syeve, 9:14 PM 8/2/2002]
Old Aug 2, 2002 | 03:06 PM
syeve's Avatar
Default Re: head gasket on backwards? (syeve)
anyone?
Old Aug 2, 2002 | 04:46 PM
legendboy's Avatar
It may be blown, not upside down
Old Aug 2, 2002 | 06:38 PM
Brian_92GSR's Avatar
New User
If it is not on the right way it would be leaking massive amounts of oil.
Old Aug 3, 2002 | 12:34 AM
syeve's Avatar
Default Re: head gasket on backwards? (legendboy)
you can blow a 3mm copper gasket???? i've drivin it for about 25 kms...every time I get it out (even on the lambda) it overheats...
Old Aug 3, 2002 | 10:29 AM
legendboy's Avatar
Did u replace ur head bolts when u put the gasket in?
Old Aug 4, 2002 | 10:23 AM
syeve's Avatar
no, just used the stock ones...tell me I can use the stock head bolts...please
Old Aug 5, 2002 | 07:03 AM
legendboy's Avatar
Default Re: head gasket on backwards? (grncivic401)
Your not suppose to with boost, duh
Old Aug 5, 2002 | 07:11 AM
CovertFI's Avatar
well duh
sorry i could not help my self. well anyway how would using the stock head bolts cause it to over heat. he did not say it was leaking or anything. duh!
i would bet you have air in your coolent, or pipes or what ever. just blead it and see if that helps.
Old Aug 5, 2002 | 08:04 AM
1fstevo's Avatar
New User
May I ask you why not? Bet you most people here has stock bolts. I use ARP but been boosting for a year with stock bolt until I took it apart again and add ARP while at it.
Old Aug 5, 2002 | 08:12 AM
BoOsTeD_eK's Avatar
Default Re: head gasket on backwards? ([Evo]Hybrid)
If your block is not properly o-ringed then mass amounts of coolant will seep into the combustion chamber...causing you to overheat.
Old Aug 5, 2002 | 10:53 AM
RuthlessEF-9's Avatar
Default Re: head gasket on backwards? (BoOsTeD_eK)
it could be upsidedown cause my friend did that
he actually put it upside down and wrong side there should be a hole for the
vtec oil pressure on (assuming you have a sohcVTEC) left side and there should be a label on the head gasket to say which way is up
hamizle
Dec 1, 2009 04:55 PM
da_33
Jan 11, 2007 11:12 AM
Lewcis
Jun 24, 2004 11:02 PM
Screamer
Apr 15, 2003 05:50 AM
filetofit
Aug 13, 2002 08:49 PM
