Head gasket?
Old Oct 8, 2004 | 11:57 PM
crispydee's Avatar
Default Head gasket?
Started loosing a little bit of water. Thank it might be the head gasket but there is no water in the oil or oil in the water. The pipe going to the rad seems to get really hard too. The head gasket was only done about 3000 mile ago but i did reuse the head bolts any ideas?
Might get a thicker gasket this time and bolts so any one with some contacts would help as there is not many turbo part available here in the UK.
Old Oct 9, 2004 | 12:04 AM
Lucky_Smurf's Avatar
Default Re: Head gasket? (crispydee)
Are you getting any over heating problems or anything? I've seen overheating when the head gasket didn't seal.
Old Oct 9, 2004 | 06:12 AM
HitEm'Up's Avatar
Is there any odor?Or smoking from the exhaust?
Old Oct 10, 2004 | 01:26 AM
crispydee's Avatar
It was smoking a little, but that was my oil return had a slight slope but thats ok now and i have no smoke. I think i might have cured it tho.
The pipe that does from the radiater to the expansion tank has touched the down pipe and now has a hole in it. When the pressure built and it push some water out to the expansion tank it was leaking through this pipe, when the pressure dropped it sucked air.
Have made i little bracket to hold it away now.
jdmitrdc2
Apr 15, 2009 11:31 AM
zcmotor
29
Apr 18, 2008 10:20 AM
EnjoyTheRideDC2
May 19, 2007 08:58 AM
hondaboyz94si
Dec 10, 2005 06:13 PM
b00stedbyFastrax
Aug 5, 2002 08:32 AM
