Having probs with the blitz dual TT
I installed it according to the directions, but when I shut down the car only the electrical stays on. BTW, for the ignition(greeen) line I tapped into the IG1 line, the accessory (blue wire) got tapped into the accessory line, and the 12 constant (red wire) was tapped into the battery line from the two wiring harnesses under the steering column.
Anyone have similar probs or some insight?
Thanks,
Jeff
Thanks,
Jeff
Yeah i had the same problem, not with the BLITZ duel tt. When i turn off my ign, only the electronics would stay on but not with the car. My TT has two ign wires to it. So what i did is just switch the two ign wires, then it worked perfectly fine! I'm pretty sure yours have two ign wires.
crxaddikt
Jun 23, 2017 05:08 PM
