having pistons milled down?
Old Nov 1, 2009 | 04:01 PM
thumper64's Avatar
Default having pistons milled down?
I have some 81.5mm forged pistons I can't seem to sell and I want to run about 10:1 compression. The pistons look like they're around 11-12:1, like a dome larger than a ITR piston but smaller than CTR. Would it be possible to just mill the dome off the pistons to make them flat like a GSR piston? Is that too risky?
My goal is to build a GSR turbo motor running about 10:1 compression, around 8-10lbs of boost on a Turbonetics T3/T4 I'm planning on running Crome on a P72 ECU and street tuning it until I get more money and can get a dyno tune. The car will be daily driven, so reliability is very important.
Old Nov 1, 2009 | 09:05 PM
Turbo B18C EJ6's Avatar
Default Re: having pistons milled down?
I wouldnt do it if you are looking for reliablity, you will end up creating hot spots on the pistons. your better off buying the proper pistons.
Old Nov 1, 2009 | 09:12 PM
philafelman's Avatar
i used to have a similar set, i believe they were +5cc domed. youre probably better off just buying a new set, milling them down, smoothing edges, and getting them all weighed properly might cost close to just as much.
Old Nov 2, 2009 | 12:22 PM
ScorpionT's Avatar
Pistons are designed with proper quench areas and are more high tech than just metal slugs. Buy a new set and avoid potential problems.
Old Nov 2, 2009 | 02:54 PM
Urban_Indian's Avatar
reliable?
why not, get a belt sander a go to work
Old Nov 2, 2009 | 07:14 PM
Tjabo's Avatar
If he's only having the domes milled down by a precise amount, and then re-matching for weight, why would it cause any problems? Quench areas shouldn't be affected if these are truly "domes."
Old Nov 2, 2009 | 11:58 PM
thumper64's Avatar
...found an issue. These are forged where the dome is the same thickness at the inside as the outside. Removing anything would make them uber thin... and one has a cracked ring land...
Old Nov 3, 2009 | 08:46 AM
Tjabo's Avatar
Oooops, there's the answer to my question!
Oh well. I used to do it with my old forged V-8 pistons Heh heh. . .
Ryan#1
Oct 2, 2008 06:27 PM
bustdgst
Aug 13, 2008 09:13 PM
Spectrum24x
Mar 9, 2006 07:14 AM
masteryoda10
Jan 30, 2006 04:30 AM
respectblades
Jun 23, 2003 09:08 PM
