white smoke
Old Nov 3, 2009 | 09:46 AM
vonttcha's Avatar
Default white smoke
my car is shooting white smoke from the exhaust...i just swapt a blox manifold into my 92 gsr...i did not replace the intake manifold gasket...i need help....i dont know if its the head gasket or the intake manifold gasket that is bad....should i replace both or just the intake manifold gasket or is it something else...? please give me some advice...thank you
Old Nov 3, 2009 | 10:44 AM
NonovUrbizniz's Avatar
Loved
Default Re: white smoke
It's most likely the last thing you worked on if it wasn't like that before... Intake manifold makes sense... if the gasket is no good the coolant could be shooting into on of the intake ports...
Always change the intake gasket when you remove it.
Old Nov 3, 2009 | 12:38 PM
Turbo-LS's Avatar
Uh you ALWAYS replace the intake manifold gasket when you replace or remove the intake manifold period. Thats your problem and stop driving the car untill you fix it, thats a great way to hydrolock your engine if you get to much coolant in cylinder 4, also change your spark plugs when your done and do an oil change
ed23cate
Jan 23, 2016 08:29 AM
vonttcha
Nov 11, 2009 06:54 AM
GsrVtec
Sep 13, 2006 09:53 AM
Shizznaz
Sep 2, 2005 08:07 AM
dualknuttz1
Jan 23, 2004 08:37 PM
