Has anyone run GT45 on street hondas?
I know many people run GT42R on their hondas but never heard anyone run GT45 on their hondas. I'm assuming these are not ballbearing cuase they're not water cooled. any input
1.05 a/r exhaust housing
Re: (vaporboy12)
If you're running that large of a turbo on a street honda, you already have a deathwish. Just cut out the rad support and whatever else gets in the way.
Would there be any logical reason for not just running a smaller turbo with more psi? I can't see any street-legal car (DOT rubber) using the 800+ hp capacity that turbo would have on a honda. Most 400hp cars have traction problems into 4th with drag radials on the road.
Re: (vaporboy12)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vaporboy12 »</TD></TR><TR><TD CLASS="quote">42r takes up alot of room i cant see fitting a 45 in there. we dont have supra engine bays </TD></TR></TABLE>
From the pictures it does not look any bigger than GT42R
Re: (HiProfile)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HiProfile »</TD></TR><TR><TD CLASS="quote">Would there be any logical reason for not just running a smaller turbo with more psi? I can't see any street-legal car (DOT rubber) using the 800+ hp capacity that turbo would have on a honda. Most 400hp cars have traction problems into 4th with drag radials on the road.</TD></TR></TABLE>
On a street driven Honda? Stupidity comes to mind if not only for bragging rights...
Re: Has anyone run GT45 on street hondas? (Turbocivic94)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turbocivic94 »</TD></TR><TR><TD CLASS="quote">1.05 a/r exhaust housing</TD></TR></TABLE>
There's your reason right there.
You can do it on a v6 accord maybe and it woudnt be that bad..or maybe an h-series/f-series motor bore and stroked out..It's gonna be laggy regaurdless though..
Re: (Boostfed.com)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boostfed.com »</TD></TR><TR><TD CLASS="quote">GT60 and PT106 is where it's at!!!! Street driven full spool at 9500 rpm shifting at 11500 rpm! YEEEAH!!! lolololololol</TD></TR></TABLE>
Maybe I should try it.
Re: (Turbocivic94)
Maybe I should try it. </TD></TR></TABLE>
And a 102mm stroke crank and 87mm bore B series you go buddy! DAILY DRIVEN!
Re: (Boostfed.com)
And a 102mm stroke crank and 87mm bore B series you go buddy! DAILY DRIVEN! </TD></TR></TABLE>
Damn, I thought it would work on my b16
Re: (Turbocivic94)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turbocivic94 »</TD></TR><TR><TD CLASS="quote">Damn, I thought it would work on my b16 </TD></TR></TABLE>
****, I put one on a D16 once and it worked awesome!!!
Re: (Jared)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jared »</TD></TR><TR><TD CLASS="quote">Good lord I hope you aren't serious. What is wrong with people. No street car needs a gt42, and sure as hell not a gt45.</TD></TR></TABLE>
Jared READ, I said to do a GT60 or PT106 102mm Crank 87mm Bore B series motor!
Re: (Boostfed.com)
with my boost controller turned off....on 25 inch slicks.....clutch out......from a roll.......with a GT35R......my car had Z-E-R-O traction on the street.
i think a 45R is gonna just be too small.
Who is Mr Robot?
Re: (Turbocivic94)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turbocivic94 »</TD></TR><TR><TD CLASS="quote">From the pictures it does not look any bigger than GT42R</TD></TR></TABLE>
its much larger, and isnt ball bearing because its a big shaft turbo, not to mention most come with a t6 inlet flange
Re: (Turbo-charged)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turbo-charged »</TD></TR><TR><TD CLASS="quote">with my boost controller turned off....on 25 inch slicks.....clutch out......from a roll.......with a GT35R......my car had Z-E-R-O traction on the street.
i think a 45R is gonna just be too small.</TD></TR></TABLE>
I guess I cant use GT45 then. I was trying to avoid the GT42R bandwagon
Trying to start a new bandwagon
Re: (Kaotic Kustoms)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kaotic Kustoms »</TD></TR><TR><TD CLASS="quote">eh.. im seriosly rethinking me getting a gt40 for 550 whp.... maybe gt35r?</TD></TR></TABLE>
gt40 is too big for 550hp. think sc61 or gt35
