Has anyone here run the GT2871r, 3071r, and 3076r?
If so what are the characteristics of the turbos? I've read through searching go with the 3071 over the 2871 because they basically spool the same. And then I've also read to go with the 3076 over the 3071 because spool is the same. It seems to be an understandable yet constant trail of "go just a touch bigger because its basically the same". So you go from a GT28 to a GT3076 and from what you read it's basically the same.
So has anyone actually owned or ridden in these and can give first hand experience and opinion on how they react such as spool time and recovery?
Re: Has anyone here run the GT2871r, 3071r, and 3076r?
Everyone and their brother runs gt30s, they're very common and spool very quickly. The gt28 will spool faster, probably not by very much and will sacrifice some power.
If you think you'll be more power hungry get the gt30, but both have good resale values if you would ever like upgrading.
I have also seen that the GT3582R spools about the same as a GT3076R but recovers slower between shifts. I liked the GT3076R and I hope I like it even better with the TR3030R upgrade.
See Tony The Tigers video of his Integra rocking a GT28(71?) R. Then go find a video of a GT3076r car. The response from a GT28r is almost instant. There is a noticeable difference.
There is tons of videos and data to go on these days. Should be easy to decide.
https://honda-tech.com/forced-induct...t2871-1848243/
Another 30R car. 10psi compared to GT28R graph above, about 1000 rpm spool difference. And that's on paper. On the street the transient response is obviously going to be much different as well.
Lightning are you talking about the GT28rs or the GT2871r? Because from what I've read there is a difference in spool time between the two. Someone even mentioned Tony said there was a bit of difference. And I'm not interested in the GT2860rs at the moment. Give it a couple days and I could be. lol But no seriously, I'd at LEAST like a turbo that can support close to 400whp and hopefully 450whp (which I know the 2871 can't)
GTX3067R, interesting
but then there is this
So a 4201whp GTX2867R followed with this description of it...
And then there is a video of it being said these are good to about 350whp. So how does one get 421whp? I understand how well the motor flows will determine the amount of power per lb but I thought a turbo was maxed out at XXX no matter what?
"Exhaust flow" is a very difficult number to figure out... It varies too much, and too much of it is left to guess work. E10 vs regular gasoline, that changes it. Race gas or E85, etc... changes it greatly. Just by working with Garrett with a sponsored car for several years already, I have supplied them with numbers of all sorts, and it is very difficult to come up with any specific turbo choices unless you have some data to give them as a starting point. I have purposely given them data from another car to see if they can come up with a figure, but too much is left as guesswork and needs real world testing. I have literally submitted information from my own personal Evo 9, but they gave me a turbo that works good for a Honda; yes, that's right, they recommended a GTX3076R from the data I sent which was from my Evo...! In the earlier years, their data was obtain from a 420WHP GTX2867R Civic. Seeing such drastic difference between different engines that are requiring turbines up to 2-3 families apart kind of shows that we are dealing with over 30%+ variance. From there, you can almost say that a GTX3067R and a GTX3082R is just as good of a turbo on paper, but the rest falls onto real testing. As long as both wheels are not worlds apart in turbine RPM and flow regions, which you are explaining, it will work. The newer GTX wheels with their wide range does exactly what it needs to make sure the turbine doesn't fall off the grid at any given turbine RPM.
Doozo.
GTX2867R - 421whp @ 1.36BAR
Nice torquey units these are..
The GTX3067R uses the same compressor wheel but with the 60mm turbine wheel of the GT3076R and GTX3071R
This turbocharger is best mated to 1.6-2.0 Litre applications that want to expand upon the capabilities of the GTX2860R to the next level in terms of mid-range horsepower. it allows for slight amount of higher top end power than the GT2860RS, but not too much more considering it contains the same exhaust wheel.
I guess what I'm ultimately looking for is the most responsive 450whp/max turbo out there that would be good for the street.
I know the 2871 will never get there, I just keep holding onto it because of the response it seems to hold over the rest.
The 3071r would make it to 450 or at least close and the 3076r would. But both would hold more lag over the 2871. I want 3076r power with 2871r spool.
I guess that's a better way to put it, maybe?
https://honda-tech.com/forced-induct.../#post50245679
A great read around #63+
What I want to avoid is 150whp....160whp.....162whp....165rwhp........370whp.......390whp
AKA I don't want that instant surge of 200whp that will do nothing but blow the tires off. (what causes this anyways?)
On paper it seems that way. My 28R made 300 ft-lbs by 4000 rpm and it was by no means blowing the tires off the way my SC6152E did once it got into power. Not to mention the response of the turbo goes along way with being able to modulate it with the throttle to achieve the 'smoothness' you want.
This was my GT2560R so quite a bit shy of 450whp capable (300whp maxxed)
The GT/X3071R sounds like the best off the shelf unit for your goals. Or something more custom (like an STC unit).
Man I can't tell you how many times I've watched each of your videos. Nothing I haven't seen, that's for sure. I agree with you, I keep going back to the GT3071R. I think I will speak with STC about anything custom that would be better but I want to stick to around $1300 otd ready to go on.
Anyone with any other options feel free to step in. My ultimate plan:
Once again, just like on the transmission thread, you act like your proving me wrong about something when you aren't. Ok, it spools a decent amount quicker, does that somehow remove the gt30's credibility as a recommendation that gives a bit more headroom and still very fast response /low boost threshold? No, it does not, don't even attempt to tell me it does in any way. Furthermore, unless there's another I'm unaware of, Tony runs a gt30on his Integra. I mean seriously man, it's just funny/ironic at this point
Eat a snickers or something 👈
Uhm, cool?
Uhm, cool?
That was all for stopsign dont worry.
But you did say
Anyways, why get one of those when you cam pump out '470whp' out of a 57 trim, remember?
Heard those come in ball bearing as well if you're concerned with transient response 👉
http://youtu.be/xcxmLtQOV2U
A 350 hp turbo is a lot different than a 480(ish) hp turbo. But hey, I'll pretend it's the same for you
Honestly you might as well have gave him this for his turbo choice : Just Flip A Coin
More info found while searching worth mentioning
Wonderfully linear. Perhaps this is why the GTX2867R may exist. Top find that "in-between" for those needing mid-range linear top-end power for those split between the GT2871R, and GT3071R. Turbine housing choice is an important factor, but really it's the full compressor/turbine wheel/engine package.
Thanks for this,Tony..real example, here.
I mean, since you are searching for just the craziest spool along with gt30 power (which already gives you crazy spool) then why not look at twin scroll options? I'm not particularly knowledgeable on them since nobody here in the honda game really used them all too often, but I believe to have seen evo 9 turbos get pushed to around 450whp.
There is quite a number of ways to define spool, and usually I'll try to avoid mixing them up between response / spool / recovery conditions. What you see on a dyno chart is just spool up in relation to RPM without using "time" as a major factor.
the GT28 based turbos spool up from low RPM very quickly and requires almost no lead time to spool up. I would classify the spool up to be like any stock turbo car, of not, better.
When guys point out that a GT30R spools almost the same, they are indeed correct. If you load up a GT30R turbo in an dyno pull condition starting from a low RPM, they both spool up very similarly. The lag difference is actually a difference in response, or how quickly the turbo flashes up into power at any RPM within the spool range.
Unless your car is a full size Civic sedan / Accord or something heavier than your typical hatch, the lag is really not noticeable between the two. Circuit racers tend to prefer the GT28 turbo due to better resolution of power (i.e. greater control over power with a smaller turbine). The GT30R will be more snappy and has less resolution for controlling power with your throttle. It moves towards being an on/off switch at higher RPM's.
On a street car, your power goal will determine what size turbo to choose. If you are looking for 400WHP or more, then your choice will automatically have to be a GT3071R.
I would only choose a GT3076R if you have plans to go up to to 450WHP and plan on staying with pump gas (not E85). The larger compressor will help the knock limit on a given fuel.
I have had all the turbos mentioned above, including the GTX variants on the same car. I would consider a divided scroll GTX3071R to be complete overkill already in terms of spool. I can almost never use the powerband unless I was literally two gears "in the wrong gear" -- as if I was supposed to be in 2nd gear, but I was in 4th gear -- way too much powerband for a FWD car that can rev to 9000+ RPM. I would be totally happy with an open scroll GT3071R (or flow equivalent GTX3067R) or a GT3076R (or flow equivalent GTX3071R)
Just check my last post for my opinions regarding the different turbos (plus I gotta update my sig, it's outdated again...lol)
Moderator
Now, even though I promised to Stopsign32v that I won't say anything anymore in his threads, for the rest of those interested in this theory for the forum, there's one more (actually two, but I'll stick to the point) that can come close to what Stopsign32V is looking for. Tony gave a subtle hint to it already. *hint* on the border between the GTX28 and GTX30 families.
But, he wants to learn as much as he can in a polite and in a manner which gives the atmosphere of good "kumbya", so that he can search for answers from others in peace.... So,for now...
