Has anyone ever done this before?
Old Jan 10, 2006 | 02:26 PM
  #26
yee SERIOUS's Avatar
looks like it would take some time to setup. and people are just gonna wanna tuck it
Old Jan 10, 2006 | 02:30 PM
  #27
Boostfed's Avatar
New User
For Fuel lines sure some hard lines would work, not sure about copper BUT why would you even want to do the feed or returns like this Geoff? Like I told you the other day you got too much time on your hands K.I.S.S.
Keep It Simple Silly(Stupid) hahaahaha
Old Jan 10, 2006 | 02:33 PM
  #28
bigdaddyvtec's Avatar
* B A N N E D *
Default Re: (Boostfed.com)
Hey that sounds like AA!!!
  #29
beepy's Avatar
Default Re: (HiProfile)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HiProfile &raquo;</TD></TR><TR><TD CLASS="quote">I wouldn't disagree with piping oil lines, but wtf was that guy thinking? I wonder if he ever heard of a distribution block? He'd have saved a shitload of parts, time, and space.
I'd also suggest compression fittings, rather than flares. They're cheap, easy to seal/install, reusable (to a degree) and are good for more oil psi than your motor will put out.</TD></TR></TABLE>
Look closer. Those are all compression fittings. It's a good idea... Like aircraft hydraulics... But if he would have used a couple distribution blocks and spent some time tucking it all, it would have looked a lot better.
Old Jan 10, 2006 | 05:11 PM
  #30
KeyserSoze's Avatar
Default Re: (Mr. Helsinki)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr. Helsinki &raquo;</TD></TR><TR><TD CLASS="quote">I bet that car is owned by a pipefitter, there's no reason to do that otherwise.
Can you imagine trying to work around all that piping? Even if I were dumb enough to run hard piping for vacuum lines, I'd certainly use stainless, not copper.
I say it's a total waste of time and money, let alone having a hundred potential leak points.</TD></TR></TABLE>
I have already done this with my last turbo setup, I only did the oil feed line, but was going to do the return as well, just didnt get around to it b4 my ringlands went. I will be doing the oil feed and return lines this way when my car is finished, I wanted to do it on all my vacuum stuff, but the damn boost solenoid (gm) has barbed ends. Those are def ss lines, if he was smart they are ss tubing and fittings from swagelok. They make kick *** fittings. Tubing rated @ 2000+ psi and will take a crap load of vibration. The compression fittings use a double ferrule that seals VERY well. You can reuse those compression fittings again and again, as long as the person who used the fitting the first time did not overtighten it and ruin the ferrules. I prolly wouldn't do hard lines from motor to anything else stationary in the bay though.
btw, I work @ a power plant so I get all the swagelok stuff I want for free 99!! I sure as hell wouldn't do it otherwise as those fittings are crazy expensive!!!!! Pretty cool setup.
Old Jan 10, 2006 | 05:15 PM
  #31
wantboost's Avatar
Who is Mr Robot?
Default Re: (KeyserSoze)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KeyserSoze &raquo;</TD></TR><TR><TD CLASS="quote">I have already done this with my last turbo setup, I only did the oil feed line, but was going to do the return as well, just didnt get around to it b4 my ringlands went. I will be doing the oil feed and return lines this way when my car is finished, I wanted to do it on all my vacuum stuff, but the damn boost solenoid (gm) has barbed ends. Those are def ss lines, if he was smart they are ss tubing and fittings from swagelok. They make kick *** fittings. Tubing rated @ 2000+ psi and will take a crap load of vibration. The compression fittings use a double ferrule that seals VERY well. You can reuse those compression fittings again and again, as long as the person who used the fitting the first time did not overtighten it and ruin the ferrules. I prolly wouldn't do hard lines from motor to anything else stationary in the bay though.
btw, I work @ a power plant so I get all the swagelok stuff I want for free 99!! I sure as hell wouldn't do it otherwise as those fittings are crazy expensive!!!!! Pretty cool setup. </TD></TR></TABLE>
i want swagelock
Old Jan 10, 2006 | 06:34 PM
  #32
KeyserSoze's Avatar
Default Re: (wantboost)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wantboost &raquo;</TD></TR><TR><TD CLASS="quote">
i want swagelock</TD></TR></TABLE>
Hey man, u kno I'll hook u up, as long as the wherehouse guy doesn't notice. Shoot me a pm and if it isn't to outrageous I gotcha. I still have that swagelok vavle as well, just shoot me your addy.
Old Jan 10, 2006 | 06:37 PM
  #33
wantboost's Avatar
Who is Mr Robot?
damn, i totally forgot about that, lol. i'll pm ya
Old Jan 10, 2006 | 06:56 PM
  #34
turboeg77's Avatar
copper lines are a no-no they break under vibration. i had first hand experience in this ended up blowing the turbo seals. never again would i use copper lines on my car. steel or stainless would work though. like on wet system nitrous set ups.
Old Jan 10, 2006 | 08:03 PM
  #35
HiProfile's Avatar
Default Re: (beepy)
I did look close. Flare and compression look virtually the same when they are only 10 pixels on my screen.
The other thing they could do to prevent cracking (during vehicle operation) is heat-treating the metal. Most tubing is annealed (softened), otherwise it would crack when elongated so much during bending. Heat treating it after it's formed gives it more strength and crack resistance.
Old Jan 10, 2006 | 08:15 PM
  #36
Boostfed's Avatar
New User
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wantboost &raquo;</TD></TR><TR><TD CLASS="quote">damn, i totally forgot about that, lol. i'll pm ya</TD></TR></TABLE>
William, me and another H-T member were talking bout you man, man you signed up for H-T in 01-01-2004 and you have 7130 Posts already, DUDE I been a member since early 2001 and you got more than 1000 posts on me WOW!!!! I need to start posting more, maybe people will think I know what I am talking about
Old Jan 10, 2006 | 08:18 PM
  #37
wantboost's Avatar
Who is Mr Robot?
hehe, i find it rewarding to help ppl, and flame the occasional retard. i read alot, post what i know, read what others know and go from there.... who was this other member? i must find out to devise my plan against you two
Old Jan 10, 2006 | 08:19 PM
  #38
Boostfed's Avatar
New User
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wantboost &raquo;</TD></TR><TR><TD CLASS="quote">hehe, i find it rewarding to help ppl, and flame the occasional retard. i read alot, post what i know, read what others know and go from there.... who was this other member? i must find out to devise my plan against you two </TD></TR></TABLE>
Nah we are The Untouchables
Old Jan 10, 2006 | 08:20 PM
  #39
wantboost's Avatar
Who is Mr Robot?
or so you think... i have my ties/contacts. I WILL GET YOU
Old Jan 10, 2006 | 08:28 PM
  #40
Dmc1's Avatar
Default Re: Has anyone ever done this before? (Boostage)
You forgot one key component.
Old Jan 10, 2006 | 08:41 PM
  #41
wantboost's Avatar
Who is Mr Robot?
Default Re: Has anyone ever done this before? (Dmc1)
Old Jan 10, 2006 | 09:07 PM
  #42
lucidvtec's Avatar
lmao.....flux capaictor
Old Jan 10, 2006 | 10:48 PM
  #43
D@nnY's Avatar
what happens when the motor rocks ? it looks like they will bend..... I think it looks like the inside of a toilet bowl but thats just me
Old Jan 10, 2006 | 10:54 PM
  #44
* B A N N E D *
Default Re: (D@nnY)
ha ha ha... ya WAY to busy and inconvienient... Nice work in execution though
kungfuSiR
Suspension & Brakes
Apr 30, 2012 05:35 PM
shrug
Nov 4, 2004 06:21 PM
DC2 to AP2
Oct 25, 2004 11:08 PM
SilverDc2
25
Oct 11, 2004 12:29 PM
PrecisionH23a
Sep 16, 2003 04:21 AM
