Haltech F5
Old Aug 11, 2003 | 02:17 PM
jon_'s Avatar
Default Haltech F5
Does anyone know where I can purchase one of these online...Im having a lot of trouble finding places that sell them.
Old Aug 11, 2003 | 04:11 PM
jon_'s Avatar
Default Re: Haltech F5 (jon_)
Anyone?
Old Aug 11, 2003 | 04:32 PM
spoolinlude's Avatar
I live under a rock
why do you want haltech...... just curious...... there are many more "user friendly" ems units
Old Aug 11, 2003 | 05:02 PM
jon_'s Avatar
Default Re: Haltech F5 (spoolinlude)
Well its between the MF2 or the Haltech F5...Which do you think I should get? I plan on running 5 psi daily and 8 at the track.
Old Aug 11, 2003 | 05:20 PM
Mad
check Top End Performance. i got mine a couple of years ago from them.
Old Aug 11, 2003 | 06:31 PM
I live under a rock
Default Re: Haltech F5 (Mad "b00sted" Max)
neither.......... for such low boost......... you don't need a standalone..... save your money and just get an AFC or something equivalent....... you'll be just as happy, you only need something like haltech for more modified applications.... where specfic tuning is required....... in this case....... ask anyone here what i'll say......... ELECTROMOTIVE
Old Aug 11, 2003 | 07:24 PM
jon_'s Avatar
The F5 is just an extra injector controller I believe correct me if I'm wrong. Its either the Erl MF2 or the Haltech F5...
Old Aug 11, 2003 | 09:32 PM
jon_'s Avatar
night bump
Old Aug 11, 2003 | 09:52 PM
vtec.dc2's Avatar
http://www.haltech.com.au/Dealers/dealers.html
Old Aug 11, 2003 | 09:56 PM
jon_'s Avatar
Default Re: Haltech F5 (vtec.dc2)
Yeah I already looked. The one that is close to where I live is like 2 hours away...I was looking to buy online.
Old Aug 11, 2003 | 10:03 PM
Smashback's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spoolinlude &raquo;</TD></TR><TR><TD CLASS="quote">neither.......... for such low boost......... you don't need a standalone..... save your money and just get an AFC or something equivalent....... you'll be just as happy, you only need something like haltech for more modified applications.... where specfic tuning is required....... in this case....... ask anyone here what i'll say......... ELECTROMOTIVE </TD></TR></TABLE>
Once you try an AFC and compare it to a stand alone equipped car, the difference is night and day. You'll wonder why you listened to the guys on Honda Tech and rigged up that ghetto **** in the first place
I went from FMU to AFC "hack" to an Uberchip. Every step of the way was a massive improvement.
Old Aug 11, 2003 | 10:15 PM
jon_'s Avatar
Default Re: Haltech F5 (PseudoSilvia)
Well I have a 2001 Civic so the FMU is out of the question do to my cars ghey return less fuel system. Another person who has a turbo setup that I talked to ran a SAFC and RC 440's his car bogged and liked to stall a lot even after massive amounts of tuning on a dyno. So I am going with an extra injector setup (because I pretty much have no other choice)...The question is a Haltech F5 injector controller, or a Erl MF2 extra injector controller. My shop really hates the MF2, but I have gotten so many mixed opinions on it I dont know what to believe...I saw Turbo D17's setup and he used a Haltech F5 and said it worked great, so I do not know which one to get. I have the MF2 already, but I am contemplating returning it and getting the Haltech F5. So if anybody could give me some input on which to get that would be great. Also you can IM me...my SN is: zinkyroo.
Well thanks for reading this! A to you!
Old Aug 11, 2003 | 10:30 PM
st00pid's Avatar
Tony1 turbocharged a 01 civic with teh F5 with great results.. Im sure he may be able to get you one.
Old Aug 11, 2003 | 11:43 PM
90civichbsi's Avatar
Default Re: Haltech F5 (st00pid)
if your going w/ haltech id reccomend getting the ek6 version, the guy a few of my friends go to for rx7 related stuff deals w/ haltech alot. he has seen quite a few F5 ecus failing. but if you get a good one, best of luck to you
Old Aug 12, 2003 | 06:08 AM
tony1's Avatar
Default Re: Haltech F5 (90civichbsi)
The e6k is a whole computer and will require alot more work. The f5 is a simple additional injector controller, easy to install and the car runs exactly as stock out of boost. It's really the way to go. If you want, give me a call at the shop and i'll see if i can still get one.
Tony
972-278-9744
Old Aug 12, 2003 | 04:07 PM
I live under a rock
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PseudoSilvia &raquo;</TD></TR><TR><TD CLASS="quote">
I went from FMU to AFC "hack" to an Uberchip. Every step of the way was a massive improvement.</TD></TR></TABLE>
afc isn't ghetto for such low boost.......... and uberchip isn't exactly standalone
Old Aug 12, 2003 | 07:20 PM
Smashback's Avatar
Ehhh, ok. AFC is pretty ghetto since it's just modifying signals to the ECU. Uberchip not standalone? That's funny, so you're saying Hondata isn't stand alone. Maybe you didn't realize that the Uberchip did everything Hondata could do.
Old Aug 12, 2003 | 08:47 PM
jon_'s Avatar
Im actually going with an Aeromotive Billet Digital FMU (made for returnless fuel system cars) and an msd inline fuel pump
Old Aug 12, 2003 | 09:49 PM
Smashback's Avatar
If you're going low boost, like 5 PSI, you could go with an in-tank high pressure pump in lieu of the inline pump.
Just a though...probably a little more quiet and one less thing to have sitting in your engine compartment (if that's where you end up mounting it).
Old Aug 12, 2003 | 10:08 PM
jon_'s Avatar
i think im just going to be boosting 7 daily
Old Aug 13, 2003 | 07:40 PM
I live under a rock
with all that money your gonna put into that ""standalone"" unit and fuel system...... why not do a slight build on the motor and run more boost........ to me it just sound like you got some extra change to blow
standalone/piggy back........ its all the same, whatever works for you
Old Aug 14, 2003 | 08:14 PM
tony1's Avatar
The haltech F5 is only like $400 or something. I don't think you'll be able to build your motor for that...
playahwitgame
Jul 1, 2006 06:45 AM
onemanlan
Jun 7, 2004 07:17 PM
MysteriousGSR
Jan 31, 2003 03:22 PM
Andrew 825SM
21
Dec 9, 2002 04:26 PM
M.A.R.C.
Jun 10, 2002 08:26 AM
