H23vtec vs. H22
Old 11-12-2007, 06:26 PM
T9U4ReBgO's Avatar
Default H23vtec vs. H22
ok idk too much about the H series so I was wondering if using a H23 bottom end with a H22 head is better or worth it as to just using a strait H22...any input is appriciated...thanks
P.S. For a turbo setup ^
Old 11-12-2007, 06:39 PM
Finest's Avatar
Default Re: H23vtec vs. H22 (T9U4ReBgO)
Use a Bering Strait H22.
Old 11-12-2007, 07:17 PM
T9U4ReBgO's Avatar
Default Re: H23vtec vs. H22 (Finest)
Old 11-12-2007, 11:31 PM
95greenlude's Avatar
h22 bottom end is balanced better than the h23 bottom end.
i'd just use a straight h22
Old 11-13-2007, 01:18 AM
T9U4ReBgO's Avatar
Default Re: H23vtec vs. H22 (95greenlude)
ok...i just hear that the h22 has weak ringlands so i didnt know?? but thanks
Old 11-13-2007, 01:30 AM
^the h23 is an identical block to the h22 just with shorter rods....
so the h22 is going to have the same ringland problems as the H22
now the f22 is a different story
Old 11-13-2007, 01:35 AM
T9U4ReBgO's Avatar
well how much power is iy safe to run on a h22 and not have to worry bout the ringlands?
Old 11-13-2007, 01:43 AM
from what i've read ~6-8 psi on a good tune....
Old 11-13-2007, 01:49 AM
T9U4ReBgO's Avatar
well that all depends on the turbo too...what hp is safe?
Old 11-13-2007, 05:00 AM
DfwBB6's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by T9U4ReBgO &raquo;</TD></TR><TR><TD CLASS="quote">well that all depends on the turbo too...what hp is safe?</TD></TR></TABLE>
varies man.....what turbo do u plan on running?
Old 11-13-2007, 10:49 AM
it was just a generalization.....
most people can run 6-8 psi with no problems.....on a stock block.
Brewtus
09-12-2006 11:40 AM
force-fed
01-31-2006 08:50 PM
ENERGYFORCE
03-16-2005 11:59 AM
JSMC
02-15-2005 06:57 PM
mattking93vtec
01-12-2003 10:30 AM
Quick Reply: H23vtec vs. H22
