H22A7 boosted
Old Jul 12, 2009 | 01:39 PM
soxle's Avatar
Default H22A7 boosted
hi guys,
how many safe boost is possible with mahle pistons et stock sleeves on a open-deck H22, please?
more boost with a block-guard? but the block-guard does not deforme the sleeves?
thank you for yours answers
best regards.
Old Jul 14, 2009 | 02:38 PM
soxle's Avatar
Default Re: H22A7 boosted
nobody? it's the same block like a H22A4.
just a H22 open-deck with frm sleeves.
thanx
Old Jul 14, 2009 | 08:17 PM
Hulk22's Avatar
whats the set up?
it depends on alot of different things the main thing is engine mgt.
with what your giving on info i would say 7-10lbs
Old Jul 14, 2009 | 11:02 PM
soxle's Avatar
the set up is:
eagle rods (not bought again)
mahle gold series pistons 9.0 C/R (not bought again)
block-guard or not (?) (not bought again)
I have already of my last set up on B18C (darton MID sleeves):
turbo precision SC-61
snowwater water-alcohol injection
greddy intercooler 24 (around 600hp capacity)
home made intake manifold (with a victor X base) and exhaust manifold
supertech valvetrain
70mm TB
moroso accumulator
big oil radiator
MSD 6AL and coil
nology Spark Plug Wire Set
4x750cc RC + 4X1200cc RC
walbro 255 + bosch 044
AEM EMS
if the max is 10lbs, I must sleeve........ I would like the power of my last set-up, 600whp but with more torque than the B18C.
Old Jul 14, 2009 | 11:19 PM
Rob97'SH's Avatar
H22A7 I havent heard of that block (what year was that out of?) but I'm looking to do the same thing for my A4 open block as well. I emailed Mahle about this but have yet to get a reply and also talked to Goldeneagle about sleaving. I mentioned this to the guy I talked to and he said I would be good with just the Mahles but my goals are half of what your looking at. My max goal of 350whp with a 10-1 compression with SK2 int and tuner cams Plus my T3T4 60-1. I also think that the FM plus tune (Hondata S300 for me) would be more or less the deciding factor on this. But I'm still researching this out. I don't want to waste a perfectly good block (and good money) by being cheap.
Old Jul 15, 2009 | 03:29 AM
Ovrbst_T66's Avatar
Its a high comp accord euro-r h22 engine.Freind of mine has one in his eg,makes 400whp 290tq on 1 bar.All we did was put in a 1.25 mm headgasket and arp headstuds.We tried to go 20 psi and the rod bent after a hard 4th gear pull .Do these two things and shoot for 350whp with a good tuner.
Old Jul 15, 2009 | 08:13 AM
purpleh22's Avatar
If your tuning is on, 500whp+ shouldn't be a problem. The cylinder wall prep has to be done properly - FRM sleeving is much different than others. It's an involved process using different honing and materials.
Old Jul 22, 2009 | 01:49 AM
soxle's Avatar
thank you for those informations.
but specifically, for me, the ultimate power is meaningless because it can vary from one set-up to another depending on the pressure.
what pressure sleeves can bear with or without block-guard.
who already has experience with this?
Old Jul 22, 2009 | 08:09 AM
purpleh22's Avatar
FRM sleeves are used in some Porches and are as strong as other sleeves. The issue is proper honing and setup. There is a posting about H22 - Mahle Gold pistons that details a number of builds. A common problem has been improper preparation/installation.
Old Jul 24, 2009 | 11:03 AM
soxle's Avatar
yes, thank you everybody.
in fact, frm sleeves are strong but i don't know the reliability of the open-deck with those sleeves.
and with a block-guard, the bore goes to reduce.
if it's 0.00, it's allright: just a little honing. if it's more...
perhaps, I will take a H22 closed-deck short block and put in mahle pistons and good rods?...
because frm sleeves are more interesting for the heat exchange than classic sleeves.
ps: i showed my project here:
https://honda-tech.com/forums/showth...3#post39336173
hatche1
Oct 28, 2011 07:36 PM
jdmludeturbo
Aug 19, 2006 03:55 AM
hookups214
Oct 19, 2005 04:12 PM
EgSick
Apr 29, 2004 10:21 PM
tunedbylorange.com
Jan 27, 2004 01:34 PM
