H22A topmount intercooler piping
Old May 26, 2008 | 12:45 AM
NAEGH22's Avatar
Default H22A topmount intercooler piping
Hi,
Just wondering how you guys with topmounts on h22a's are running your intercooler piping from the compressor housing to the intercooler. The problem im facing is the alternator. I have a low mount alternator bracket but space is still pretty tight. I was thinking about a backdoor entry cooler but thought i might see what everyone else was doing.
pics would be great
my setup (h22 in eg) is pretty similiar to this -
Modified by NAEGH22 at 2:10 AM 5/26/2008
Old May 27, 2008 | 06:20 AM
Bakeoff's Avatar
backdoor, all the way. As long as you have a normal civic sized radiator, it will work great. trying to route it any other way just isn't worth the hassle.
Old May 27, 2008 | 10:53 AM
PrecisionH23a's Avatar
Default Re: H22A topmount intercooler piping (NAEGH22)
Backdoor is going to be the easiest way. You'll most likely need to fab up one short pipe from the compressor to the backdoor and have somewhere between a 30-45 degree bend. Routing it around the alt is a pain in the *** regardless of if you are running the relocation kit.
I'll see if I can get you some better pictures but here's a pic of the last one we did in an EG:
Old May 27, 2008 | 05:18 PM
CE-CE's Avatar
i have a top mount on my h22 and all i used was a rubber 90, that fit around the alt perfect
Old May 27, 2008 | 10:09 PM
NAEGH22's Avatar
Default Re: H22A topmount intercooler piping (PrecisionH23a)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PrecisionH23a &raquo;</TD></TR><TR><TD CLASS="quote">Backdoor is going to be the easiest way. You'll most likely need to fab up one short pipe from the compressor to the backdoor and have somewhere between a 30-45 degree bend. Routing it around the alt is a pain in the *** regardless of if you are running the relocation kit.</TD></TR></TABLE>
yeah thats what i was thinking, although i was kinda trying to avoid it.
some other shots of that set up would be much appreciated
CE-CE got any pics of your setup?
kenbo21
Honda Civic (2001 - 2005)
Aug 27, 2008 08:45 AM
J1A1H
May 10, 2007 03:36 PM
Mr.E.G.
Sep 5, 2006 09:40 PM
DaveF
Nov 27, 2004 10:13 AM
corey's96GSR
May 1, 2004 11:06 AM
