H22 Rebuild?
Old Jun 27, 2002 | 09:16 PM
ichibanjap's Avatar
Default H22 Rebuild?
Okay, everyone is saying that you need to resleeve the block to use forged pistons, right? Well, has anyone tried to do it without resleeving, if so what were the end results. Everyone i talked to said I had to do this to my block JBR, Race Engineering, JE, ect... Except for two Importbuilders.com and EIP Tuning. Eip tuning has a project turbo and they didn't resleeve the block and haven't had any problems with their setup. And Importbuilders.com said they've done that on a couple of customer's cars and have been running them like that for a while. So my question is do you think it's a gamble or should i just save my money and resleeve the block?
Old Jun 27, 2002 | 09:34 PM
ichibanjap's Avatar
Default Re: H22 Rebuild? (ichibanjap)
Anyone???
I've already seen the old posts about this topic but no answers!
[Modified by ichibanjap, 6:34 AM 6/28/2002]
Old Jun 28, 2002 | 03:15 AM
kinesistech's Avatar
I would resleeve. I've heard the cylinder walls are nikasil. If thats true you should sleeve the block. Thats it.
Old Jun 28, 2002 | 05:46 AM
The Punisher's Avatar
Default Re: H22 Rebuild? (kinesistech)
They are not Nikasil. It is called a Fiber Reinforced Mesh (FRM). It is .5 mm thick, and you can safely bore and hone it up to .3 mm. There are a couple of reasons for this FRM. First, the sleeves are aluminium. If you have an aluminium piston and the sleeve is made from the same material, there is too much friction. That is where the liner comes in. Second, strength. The FRM is much stronger than the stock aluminium sleeve. Gotta hold that power. Yes, you can install aftermarket pistons with the stock sleeves. If you are going that far, I would resleeve though. If you need a good deal, I can hook you up with GE sleeves. I am not running a GB right now, but I do offer aggressive prcing. IM me or email me if you are interested.
Old Jun 28, 2002 | 08:36 AM
greengangsta's Avatar
check out this guy that put aftermarket pistons and didn't sleeve the prelude block...
http://www.preludeonline.com/showthr...threadid=71076
Old Jun 28, 2002 | 08:46 AM
Default Re: H22 Rebuild? (greengangsta)
One, I bet the guy didn't even hone the sleeves and two. I bet he installed the rings incorrectly. There are many people who have installed aftermarket pistons in the H22 with no issues! You can't fault the FRM for a user mistake!
turboaccord77
Feb 1, 2012 10:25 PM
91bluehatch
Apr 13, 2009 07:10 PM
michaelprice83
Feb 1, 2009 07:27 AM
shrirag
May 14, 2007 04:25 PM
acr91
Apr 6, 2004 05:20 PM
