h22 open deck and closed deck
Old Apr 4, 2006 | 08:21 PM
snzh22's Avatar
Default h22 open deck and closed deck
i have an h22a1 (usdm). is it open deck or closed deck? i heard of issues where the closed deck (the one that doesnt cool as good) blew even on low boost (7.5 psi or so)
i plan on doing low boost (6-8psi) on stock internals (no sleeves or anything) using a dsm 14b turbo. will i have a problem with cooling? will i run into any problems with such a low boost?
Old Apr 5, 2006 | 01:56 AM
ismkv8s's Avatar
Default Re: h22 open deck and closed deck (95hprelude)
yours is a closed deck and it will have no cooling problems even at higher boost. The only reason that honda changed it over to a open deck is that it is a quieter motor.
Old Apr 5, 2006 | 03:51 AM
2point2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95hprelude &raquo;</TD></TR><TR><TD CLASS="quote">i heard of issues where the closed deck (the one that doesnt cool as good) blew even on low boost (7.5 psi or so)</TD></TR></TABLE>
They're also 600lbs heavier and the sleeves are made of mahogany wood. As long as you dont rev past 3500rpm you should be fine with the H22.
Old Apr 5, 2006 | 07:21 AM
snzh22's Avatar
Default Re: h22 open deck and closed deck (2point2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2point2 &raquo;</TD></TR><TR><TD CLASS="quote">They're also 600lbs heavier and the sleeves are made of mahogany wood. As long as you dont rev past 3500rpm you should be fine with the H22.</TD></TR></TABLE>
3500? thats it? did u mean 7500?
also do u guys think the 14b is too small?
Old Apr 5, 2006 | 08:10 AM
RudeLude's Avatar
dont listen to this guy, he has no ******* idea what he's talking about, the sleeves are made from royal oak. as for the rev limit, i've peronally seen solid deck blocks run up to 3871 rpm's with two blockguards.
hope that helps
daniel
Old Apr 5, 2006 | 08:55 AM
snzh22's Avatar
Default Re: h22 open deck and closed deck (RudeLude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RudeLude &raquo;</TD></TR><TR><TD CLASS="quote">dont listen to this guy, he has no ******* idea what he's talking about, the sleeves are made from royal oak. as for the rev limit, i've peronally seen solid deck blocks run up to 3871 rpm's with two blockguards.
hope that helps
daniel</TD></TR></TABLE>
so ur saying that if i turbo my h22, i cant rev past 3871 rpm?
Old Apr 5, 2006 | 09:00 AM
93preludes's Avatar
they're joking...
you wont have any problems running a closed deck block on 6-8lbs, just make sure you get it tuned by a reputable tuner...
purpleh22's Avatar
See other postings. with lower boost that you listed, you can rev to same limits as stock. A good tune is important.
Maybe three block guards and the Balsa wood liners?
Old Apr 5, 2006 | 09:03 AM
98vtec's Avatar
moderator emeritus
Default Re: h22 open deck and closed deck (purpleh22)
fyi, honda went to open deck for better cooling of the cylinder walls.
Old Apr 5, 2006 | 09:08 AM
snzh22's Avatar
Default Re: h22 open deck and closed deck (98vtec)
k good thing theyre jokin. but anyway so i was saying low low boost on a closed deck block wont have too many problems right? also is the 14b too small? should i up it to a 16g?
Old Apr 5, 2006 | 09:15 AM
h22a_junkie's Avatar
so there is no difference as far as boost is concerned between the opened deck and closed deck? i thought i read in sport compact tuner under the h22a CRX swap article that the h22a4 was the more preferred engine of the 2 for boost applications
Old Apr 5, 2006 | 09:22 AM
djnikko's Avatar
Default Re: (h22a_junkie)
I "heard" the closed deck version is better for boost somehow. I think the liners are held in place more so by the structure of the block than on the open deck but dont hold me to that.
For turbo your best of with a T3/T4, Precision SC-61 or T70 but expect a bit of lag on the last 2, again only from what ive read. Im starting off with a T3 .AR 60&48 to get me started then im swapping out to a SC-61 or T70.
Good luck
Old Apr 5, 2006 | 09:37 AM
snzh22's Avatar
Default Re: (djnikko)
im keepin stock internals so i dont need anything big. thats why i wanted to go with a 14b
Old Apr 5, 2006 | 11:48 AM
2point2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by h22a_junkie &raquo;</TD></TR><TR><TD CLASS="quote">so there is no difference as far as boost is concerned between the opened deck and closed deck? i thought i read in sport compact tuner under the h22a CRX swap article that the h22a4 was the more preferred engine of the 2 for boost applications</TD></TR></TABLE>
The only time you really need to worry about the difference between H22As is when you're building a hardcore setup..
Honda went with larger mains and open deck on the newer H22s (but i think there is an oddball year?). This might appeal to people who are looking for crazy whp #'s or very high revs, not to the average joe who wants to burn some rubber.
Choosing a turbo is easier than most people make it out to be (I've been there too!). Just see what works for other people and go from there. With enough searching and googling you'll find someone with a similar budget.
Rudelude, there's no way an H22 can rev to 3871 without Year2000Motorsports.com African hardwood replacement sleeves, helium filled pistons and welded exhaust ports.
Old Apr 5, 2006 | 11:49 AM
2point2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by purpleh22 &raquo;</TD></TR><TR><TD CLASS="quote">Balsa wood liners?</TD></TR></TABLE>
light weight!
Old Apr 5, 2006 | 12:33 PM
DurboDug93's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2point2 &raquo;</TD></TR><TR><TD CLASS="quote">Rudelude, there's no way an H22 can rev to 3871 without Year2000Motorsports.com African hardwood replacement sleeves, helium filled pistons and welded exhaust ports.</TD></TR></TABLE>
Ive actually had better results with the Neon filled pistons vs the helium filled. The higher atomic weigh of neon results in a more stable structure, which will ultimatley hold up better under boost.
Old Apr 5, 2006 | 12:46 PM
Semnos's Avatar
SC61 spools super quick on a H22.
I wouldn't use the 14b IMO.
Can't go wring with the SC61
Old Apr 5, 2006 | 12:53 PM
I Have an STD's Avatar
wrenchin'
Default Re: (Semnos)
ok, if you put a 14b on the H22 it will be BARELY faster than stock. a 16g is also o small for an H22. the smalles dsm turbo i would use (because im sure ur using a stock DSM manifold for this) is a 20g. but seriously, you have hondas 2nd biggest vtec motor. use your displacement. get a big turbo and make some real power
Old Apr 5, 2006 | 01:58 PM
snzh22's Avatar
Default Re: (I Have an STD)
how much boost is the 20g good for? is it still fine on stock internals?
Old Apr 5, 2006 | 02:16 PM
wrenchin'
Default Re: (95hprelude)
the 20g is good for 20+ psi. its also not cheap. expect to ay upwards of 400 for one. serously, just buy a real turbo, please
Old Apr 5, 2006 | 02:29 PM
snzh22's Avatar
i dont think i can get 20+ psi out of a stock internal h22. any suggestions for what would be the best with a stock internal h22?
Old Apr 5, 2006 | 06:06 PM
RudeLude's Avatar
lol, u guys crack me up...on a real note though, i have an h22a solid deck, i'm boosting with an sc44, 8psi, tuned on uberdata, i havent dyno'd as yet, just street tune, but i dont think i can squeeze much more that what i have now, i would say it putting out around 300whp. feel sick as hell, i'm getting a set of mahle and eagles and upping the boost, if i'm not happy i'll get the sc61 s cover...everything is stock in my motor right now, for like 6k miles now, always romped on, never had a prob.
Old Apr 6, 2006 | 06:34 PM
Slick00Lude's Avatar
the h22a1(92 - 96) is a close deck motor. The h22a4(97 - 01) is an open deck motor. Open decks do cool better than the closed decks due to the open deck's coolant jackets being exposed, but the closed decks are a bit stronger because of the extra mass around the cylinders. If your not going with a crazy setup, open deck or closed deck shouldn't matter. In the case of a high boost/horsepower setup, the closed deck will hold higher boost but the downfall could be cooling. If your serious about a build up, dont skip on anything, motor, turbo kit, suspension, cooling, tuning. You must do it all right. There shouldnt be a problem though if your just looking for "small" power. Eaither way, if your looking to build your h22, sleeve it, build it properly, and tune it. Your setup is as only good as the tune. Do it right the first time. Until then, learn as much as possible.
Old Apr 7, 2006 | 10:30 AM
snzh22's Avatar
Default Re: (Slick00Lude)
my plan is to piece together a turbo kit. i think im gonna use the stock evo trubo (16g i think), stock evo manifold (needs to be redrilled, but the ports line up perfectly), and a stock evo intercooler.
my inspiration -
http://www.homemadeturbo.com/f...064.0
just w/o the anti-lag
Old Apr 7, 2006 | 01:07 PM
under_OATH's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95hprelude &raquo;</TD></TR><TR><TD CLASS="quote">i dont think i can get 20+ psi out of a stock internal h22. any suggestions for what would be the best with a stock internal h22?</TD></TR></TABLE>
I ran a stock h22a1 for a while on 20 psi with my sc61.... motor holds fine.. just have to be conservative on the timing.
