h22 gt35r what will excactly will I need
Finally got my maintnence done after 3 months of waiting on all parts got car running and about a week in since my power steering was deleted and not sealed my rack and pinion broke...so now I am just gonna do this right and throw it in a del sol of civic..my heads fully built and just got a wet kit for cheap and got some crower turbo/boost cams for the spray but decided to go with a big turbo.I'm lookin to do this right and keep posting but first I need to know what else I will probobly need and should I go gt30r or 35r??What you think?Also my buddy mentioned that I need a closed deck , re sleeve , and im sure pistons/rods this true?I know its high compression but just makin sure what it can handle?...thanks
Re: h22 gt35r what will excactly will I need
as long as i make over 320 id be happy I plan for the car be possibly street probably just track though..and yeah I heard only difference between gt30 and 35r is a little more top end(for the 35r)
if you want your bottom end bullet proof get it sleeved by (benson, or golden eagle), get nice pistions like CP's and rods like (pauter, or carillo). i would get the crank micropolished, new bearings for the mains and the rods, and new seals for the bottom end and you should be good to go. ( the above block should make some nice power paired up with the accommodating turbo and manifold).
in addition for the turbos you have in question look at the graphs garret has on their website and pick for your self.
http://www.turbobygarrett.com/turbob...R_714568_3.htm
http://www.turbobygarrett.com/turbob...30/GT3071R.htm
hope that helped.
CP makes great pistons (i would get 9:1 compression so it wont be dead out of boost) eagle makes some good rods, it really depends on how much you want to spend.
Well you have to sleeve it to run the CP's or do get press in liners like they do on closed deck V8 motors. Any machine shop will do it aslong as the h22 your using is closed deck. And for just 320 hp Je, Srp, Cp, Wies, mahle are all good pistons to use.
hope that helped.
hope that helped.
Moderator
You also need to state a budget for the turbo your going to get, the manifold, as not all turbos may fit correctly, and how you want the car to behave (drag, street/strip, etc). There are TONS of choices outside of the GT35R and GT30R, even though they are great choices. Do you understand the difference in journal bearing and ball-bearing cartridges other than one might be "better"? Do you understand the risks and responsibilities for such expensive units?
Just be careful, talk to people w/ similar setups to what you're trying to create, talk to the pros, get feedback. etc. Looking compressor maps are great, but if you don't know the math or the characteristics you're looking for (not to mention how to read such a map), it is useless.
You said it yourself. Take your time, do it right, and be as Specific as possible. Don't lie to yourself and you're needs trying to "figure it out". You'll more than likely be disappointed.
GL. PM me w/ questions.
awesome thanks for the help...and yes I understand the difference between the two..and I plan to make much more power than what I said im just sayin Id be happy with that but i want to go with a gt30r or 35r.Im startin to have an idea of what I need to do i am not really in a rush or have a budget like I said I just want to do this right because I am sick of maintnence problems
JaGuAr81
06-08-2022 04:05 PM
nerD_alert
05-21-2012 07:10 PM
Rev
02-04-2007 09:10 PM
